Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
house electrician,,,
Old Nov 27, 2010 | 10:18 AM
basicstrategy777's Avatar
basicstrategy777
St. Jude Donor '11-'12-'13-'14-'15-'16-'17,'20, '21,'22, '23
Default house electrician,,,
can anyone recommend a house electrician. reasonable and good.
circuit breaker keeps popping. I reset it and 2 seconds later it pops.
can't get my cars out of the garage.
777
Old Nov 27, 2010 | 10:31 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
how many door openers?
does it trip before using them, on its own?
you can pull the string connected to the chain slide on the opener, and then use the door manually until repairs are made
if you have 2 door openers, unplug one at a time and see if breaker trips, thereby isolating the problem, what else is connected to that breaker? anything esle besides door openers?
is it a GFI breaker?
could be a weak breaker if nothing else has changed...
Old Nov 27, 2010 | 10:45 AM
Subfixer's Avatar
Subfixer
POSSE ZR-1 Driver
Let me know if you need any help.
Looking for an excuse to get out of working on the business financials....
Old Nov 27, 2010 | 10:48 AM
basicstrategy777
Thax Steve.
I busted thru the doors with the cars, now I need body repairman. (just kidding)
It is not an overload situation so it there must be a short somewhere. I disconnected the electric doors and reset the breaker and it popped, so I know it is not them ; there must be a short somewhere or a loose wire.
Thanks for the advise.
777
Old Nov 27, 2010 | 10:52 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
need to figure out what else is on that circuit....could be another load somewhere....possibly a GFI outlet outside the garage or back of the house..if so, see if "it" is tripped.....if not, still could be the breaker itself if nothing else on that circuit
Old Nov 27, 2010 | 11:03 AM
basicstrategy777
I'll try one more thing.....thax again Steve. 777
Old Nov 27, 2010 | 11:08 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
If it's a GFI circuit causing the problem, the breaker would not trip. GFI's trip several thousand times faster than traditional breakers, and that's why they're used for safety.
Assuming it's a 15-20A breaker, there's something on there that's causing the breaker to immediately trip. Could be something as little as a string of chirstmas lights that have a plug sitting in water, or a sinister as a frayed wire inside a wall.
Don't eff around with this. Call a licensed electrician out immediately. Cost is negligable towards your house burning down. Also, for insurance reasons, the licenced electrician gives some CYA.
Old Nov 27, 2010 | 11:16 AM
basicstrategy777
Thax NJ....I called an electrician and he wants 85 dollars an hour....I should have taken industrial arts courses in high school instead of friggin' college courses.
I will, in all likihood, call him out. Your advise is sound.
777
Old Nov 27, 2010 | 11:19 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
it could be this....
serioulsy, let me know how you make out.....nothing else on that circuit you can unlug or eliminate?
Old Nov 28, 2010 | 05:07 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
are you back in business?
Old Nov 28, 2010 | 05:46 AM
basicstrategy777
Thax for asking Steve.....I am out of my depth....need to call an electrician. Fortunately, nothing inside the house is affected.
777
Old Nov 28, 2010 | 06:12 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
very strange this happened all of a sudden.....seems like something was added, or a faulty breaker.....nothing else on that circuit, eh?
Old Nov 28, 2010 | 06:15 AM
basicstrategy777
happened all of a sudden......nothing was added.
777
Old Nov 28, 2010 | 07:02 AM
DAV162's Avatar
DAV162
I bet it's an old breaker. Nino if you need any help my future son in law is an electrician and is up in Bolton. How old is the breaker.
Old Nov 28, 2010 | 07:06 AM
DAV162's Avatar
DAV162
Steve how do you UNLUG a circuit new term for me.
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
save yourself some time & money...go to the Depot, pick up a matching new breaker...(brand & amp size)...have it handy for when electrician shows up....I agree it probably just has to be swapped out.
Old Nov 28, 2010 | 07:08 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
"nothing else ON that circuit"....c/mon, get that java going...
To house electrician,,,
Old Nov 28, 2010 | 07:39 AM
DAV162's Avatar
DAV162
Oh I missed that one
Old Nov 28, 2010 | 08:28 AM
basicstrategy777
Dave....you have a PM.
Breaker is part of a new fuse box that was installed at least 25 years ago. It is 200 amp service and I had the old fuse system replaced when I moved in.
777
Old Nov 28, 2010 | 11:17 AM
nj02vette's Avatar
nj02vette
777
Certainly could be a bad breaker, as others have pointed out. If you know how, no harm in replacing that first by yourself. But only do that if you know what you're doing. It's not hard, but just make sure you have the mains shut off, and know what not to touch, since there are some live wires in there.
Wish my MS Engineering degrees got me $85/hr.
