Garage floor - epoxy or tile?
#41
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
I plan on doing Racedeck when it finally warms up around here and can get some of the seasonal stuff out of the garage for good.
Hint: If you plan on using Racedeck, mention that you are a CF Member for additional savings.
Steve
Steve
#42
Supporting Vendor
St. jude Donor '14
Sorry, Dave. Just trying to help. Overall I like the racedeck. One other nice thing about it is, that if you ever decide to move, you can take it with you. Also, find someone who has it down and walk on it. You get a little bit of a hollow sound. That bothers some folks, but not me.
#44
Adding foam sounds like it may be an invitation for absorbing moisture / water and allowing mold to grow.
#45
Retired & lovin' it!
Hi Dave, there is a flooring co. in Lakewood (near you, Jackson) that sells a real nice PVC tile(1/4 thick) that lock into each other, use a rubber mallet to install. It comes in all different solid colors so you can custom design if you wish. It comes in coin top, diamond plate, and a textured finish. Let me know if you want the info and I will pull it for you.
#47
It is a different product than RD, it will make no noise and has a tight seem that liquid will not get through. The best way I can descibe it is that RD is like a platic tile while the Locktile is a flexible pvc tile. I would recomend getting a sample of both then make a decision. Locktile is used in wharehouses with forklifts running on it all day, I wouldn't make a strenght judgment based on thickness (I myself have made it before) Good Luck on your project, it will sweet on whatever you decide
#48
I haven't done anything on my garage floor, but when I do I'll probably go with rolled rubber. It's available in many styles and colors and is cheap per SF compared to these other products.
#49
garagejournal.com has tons of info on this. I went with epoxy from epoxy coat, and had terrible results the first time (yellowing), and steller results the second. Learned alot, and its tough as nails!
#50
#54
check out this guy from my first post http://www.garagefloorcoating.com/
Jeez...I'm really confusing myself. Was leaning towards Locktile, but then saw an installation that had been in place for a couple of years & was disappointed that the tiles had lost their surface sheen. Looked like old rubber tiles. And I tend to agree with the comments about water, dirt or whatever working down thru the connections in the RD tiles. l may be back to epoxy. Anyone know of a good contractor in the Monmouth/Ocean County area (NJ)?
#55
Garage Floor
I bought the floor system Epoxy from U-Coat It. Its been almost 4 years and floor still looks great. Parked vehicle all winter with snow etc and it washes very easily with water.
Bought it at their booth while at Carlisle Show
JP
JP
#56
I used Rustoleum paint and clear, looked great for four years but its starting to crack in spots, I've got chips from where my jackstands go.
Surface prep is key, I cleaned and acid washed for a day before painting and let it cure for 2 weeks before putting a car on it. If you don't let it cure the paint will come up.
If you just park I would recommend the epoxy, looks nice
If you do work in your garage I would recommend tiles, more durable and replaceable if damaged
#57
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
#58
I have had race deck for 5 years now and I don't like it at all for many reasons. It is next to impossible to clean. The only success I have cleaning it is on my hands and knees. So it is always dirty, many tire and exhaust marks won't come out. I use my garage as such, I have old muscle cars and daily drivers in there, so they leak fuids on the floor. The only way this stuff looks good is for the person who only drives their car on a nice day, and treats their garage as if it were a living room. Otherwise I would find a different option. Good luck!
#59
#60
I still have the brochure from the show, the guy is Kevin Kowaleski, 732-577-1026 I think he is in Marlboro.
The estimates are free, so it will just cost you some time to take a look at it.
When i get the funds to do my garage i am seriously considering it, or i may go with the allure flooring from home depot.
