Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
New to forum
Old Jun 7, 2011 | 05:45 PM
slj455's Avatar
slj455
Oldtimer
Default New to forum
Hi new to corvettes and to this forum. Was wondering if anyone can rec commend a good mechanic to work on a 2001 vette.
I am located in Union County NJ.
thanks.
Old Jun 7, 2011 | 05:48 PM
cjlaw73's Avatar
cjlaw73
Welcome to Vettes and the Forum.
http://www.eastcoastsupercharging.com/
Talk to Chris, Doug or Mike.
Old Jun 7, 2011 | 06:14 PM
TryNkeepUp's Avatar
TryNkeepUp
St. Jude Donor '08-'09-'10-'11-'12
Hello
What Charlie said
If you're in Jersey, ECS is your best choice, if you're in New York then I'd go with The Vette Doctors (both great shops and great friends!) - wouldn't recommend any other shops...
Good luck with the vette
Old Jun 7, 2011 | 06:27 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Originally Posted by TryNkeepUp
Hello
Old Jun 7, 2011 | 06:58 PM
CTYANK2's Avatar
CTYANK2
St. Jude Donor '07 thru '25
thanks.
Welcome to the Corvette Forum and congratulations on finally getting a Corvette. Don't forget to waive to other Corvettes! What type of work are you looking to have done?
Old Jun 7, 2011 | 07:04 PM
JerzeyJoe's Avatar
JerzeyJoe
thanks.
Welcome aboard. Lots of info. on here.
Old Jun 7, 2011 | 11:23 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Welcome!
Old Jun 8, 2011 | 07:45 AM
slj455's Avatar
slj455
Oldtimer
Default thanks
looking for a good mechanic that will be able to correct what ever I mess up DIY.....
Old Jun 8, 2011 | 09:53 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Welcome to the forum... If you need any help or just have questions let us know...
Old Jun 8, 2011 | 10:19 AM
slj455's Avatar
slj455
Oldtimer
Default thanks Chris
Chris,
where are you located?
About to try to replace headlight gear, soon as it gets here. As I have moaned on other threads, time was when I thought nothing of rebuilding an engine or doing brakes, or whatever. Its been a long time since I have done any real mechanical work, so I wanted to get a recommendation for a good vette mechanic/tech, just in case I screw things up really badly.
Thanks for the response. I am in Roselle NJ
Old Jun 8, 2011 | 12:42 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
Old Jun 8, 2011 | 01:20 PM
Mark I's Avatar
Mark I
What everyone else said.
This forum is a rare find. You will not only find good people with a common interest but some real fanatics who can answer almost any question about the car and back it up with part numbers, diagrams and instructions.
The vendors are generally pretty good too.
Old Jun 8, 2011 | 07:06 PM
EPMM 03 C5's Avatar
EPMM 03 C5
Old Jun 9, 2011 | 12:54 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Welcome. Lot's to learn here.
Old Jun 9, 2011 | 03:08 PM
Ralphyboy's Avatar
Ralphyboy
Welcome. Sounds like you've had quite a bit of experience if you've gotten into some serious engine work before. Use all the resources here, and do searches. There are plenty of threads about people changing cams, heads, throttle bodies, and all sorts of other things. Just do a search or post up a question here or on the tech section for whatever series car you have c1, c2, c3,etc . You'll get all the info you need.
Old Jun 9, 2011 | 04:00 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Welcome. Lots of valuable information within this forum.
ECS is located in Cream Ridge, NJ. About 5 mins from Great Adventure.
Old Jun 9, 2011 | 05:10 PM
slj455's Avatar
slj455
Oldtimer
Default Wow
What a great group. I belong to a few forums, music related, and thought they were full of supportive, nice people... but the responses here are overwhelming.
As far as experience, it was a long time ago. I actually graduated from Aviation High in Long Island City. And worked through college at an outfit that worked on Trucks primarily. Did some Backyard work on my own cars, just enough to keep them reliable and safe.
Most of what I learned there is obsolete. Things have progressed since 1967.
Then again some things have not.
I am hoping that there will be a minimum things that I will have to do to the vette. Plan is to keep it stock and very drivable.
Thanks again to all for the hearty welcome !!!!
To New to forum
Old Jun 9, 2011 | 08:44 PM
Bobd207s's Avatar
Bobd207s
From: Cancer Sucks - please donate to Corvettes Conquer Cancer
Cruise-In X Veteran
You can't go wrong with the guys from ECS - they are the best !
2001 is a great year for the C5's ( I obviously have one ) !!
As far as the headlight gear - there is someone here on trhe forum that makes these gears out of brass much better then the plastic OEM gears. Do a search on Brass Headlight gears and I think you'll find some valuable info on this subject
Bob in Nh
Old Jun 9, 2011 | 08:55 PM
Bobd207s's Avatar
Bobd207s
Cruise-In X Veteran
here's a link as to how to replace the gears - it was done by Patches - one of the DIY guru's here on the forum
http://forums.corvetteforum.com/c5-g...orialized.html
Old Jun 10, 2011 | 06:04 AM
Wicked Weasel
That's what they all say.....
