Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
'01 is fixed
Old Sep 14, 2011 | 03:13 PM
jmbbluevette's Avatar
jmbbluevette
2010 SC GS Driver
St. Jude Donor '13,'17,'18,'19
Default '01 is fixed
Dave at ESP called this afternoon and said the car is running again. The problem was that the electrical fuel connections at the boost-a-pump had loosen up including one that was completely disconnected. He called a&a corvettes and they said that they had encountered the problem before. The solution was simple, just use loctite in the connectors. The boost-a-pump is just behind the rear wheel well on the passenger side. I guess the design for the connectors was not the best. Loctite to the rescue again.
Old Sep 14, 2011 | 03:18 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Joaquin; Glad it was an easy fix! See you soon. D&D
Old Sep 14, 2011 | 03:23 PM
basicstrategy777's Avatar
basicstrategy777
St. Jude Donor '11-'12-'13-'14-'15-'16-'17,'20, '21,'22, '23
Glad it wasn't bad.
see you soon.
777
Old Sep 14, 2011 | 03:50 PM
jeffjob's Avatar
jeffjob
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
St. Jude Donor '13, '17-'18, '25
Nice !!!
Back on the road boosting it one mile at a time.
I thought for sure the problem was going to be your new catch can!
Old Sep 14, 2011 | 04:10 PM
Drop Top's Avatar
Drop Top
That's good news.
Old Sep 14, 2011 | 05:14 PM
CTYANK2's Avatar
CTYANK2
St. Jude 15 Year Donor
St. Jude Donor '07 thru '25
On the road again! Excellent Joaquin!
Old Sep 14, 2011 | 05:31 PM
bullmarket's Avatar
bullmarket
POSSE SENIOR RIDER
See you soon
Old Sep 14, 2011 | 07:34 PM
XEUROTRASHOWNER's Avatar
XEUROTRASHOWNER
Good to hear your running again. Is the boost-a-pump a factory item or after market?
Old Sep 14, 2011 | 07:49 PM
jmbbluevette
2010 SC GS Driver
Aftermarket. But they seem to be pretty reliable except for perhaps the connectors themselves. I guess they loosen up with the vibration of the car, which should not happen. Typically I would not use Loctite for electrical connections. But that is the bandaid approach. And perhaps the instructions should suggest the use of Loctite.
By the way thanks to all.
Old Sep 14, 2011 | 07:54 PM
XEUROTRASHOWNER
"And perhaps the instructions should suggest the use of Loctite."
or some baby lockwashers
Old Sep 14, 2011 | 07:55 PM
68sixspeed's Avatar
68sixspeed
St. Jude Donor '10 thru '26
Great news! -Dan
To '01 is fixed
