Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
NJ Private Inspection Facilities
Old Apr 16, 2014 | 02:58 AM
CDaniel525's Avatar
CDaniel525
Default NJ Private Inspection Facilities
Curious if anyone can recommend any private inspection facilities in NJ that will overlook off-road xpipe if the OBD2 test all passes?? Thanks in advance and please feel free to PM me if you dont want to post it publicly.
Chris
Old Apr 17, 2014 | 07:27 PM
corvettejack's Avatar
corvettejack
not from NJ but I just had my inspection they generally will not jack up your car and it is all-most impossible to see the under carriage with-out lifting
Old Apr 17, 2014 | 08:15 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
if you still have your cats and 02 sensors then you should be able to pass the state facility, they do a visual on the cats. they don't care about an X pipe.
Old Apr 17, 2014 | 08:39 PM
CDaniel525's Avatar
CDaniel525
In NJ most inspection stations have camera under the car...
Ive got headers and no cats in my x-pipe..
Old Apr 18, 2014 | 11:01 AM
robertaj's Avatar
robertaj
I watch them like a hawk when they run my car through.. I've never seen them look under the car nor at any camera. Given I have high flow cats, even so they only plugged in the odb2 and computer says I passed... done and done
Old Apr 18, 2014 | 07:45 PM
JerzeyJoe's Avatar
JerzeyJoe
Paramus Inspection station has cameras underneath. If your sensors are still on the car, you should be able to pass.
Old Apr 19, 2014 | 05:09 PM
rrt898's Avatar
rrt898
Default Inspection
I agree, I never have a problem. I do go to Wayne.
Old Apr 20, 2014 | 10:33 AM
CDaniel525's Avatar
CDaniel525
So, what happens if you go to a state facility, and they notice you dont have cats... Just fail the inspection and send you on your way... OR???
Old Apr 20, 2014 | 11:25 AM
rrt898's Avatar
rrt898
Default Inspection
They slap cuffs on you and shred the car!!
Yes you fail inspection and have 30 days to fix it. If it worries you, just go to a private inspection garage. Just make sure the service light isn't on. I wouldn't even thought about a few years ago but; the inspection laws in NJ have changed a lot. They do check the gas cap.
Old Apr 20, 2014 | 11:33 AM
CDaniel525's Avatar
CDaniel525
LoL - I had read stories of them giving you major fines from the EPA or some crap like that...
I tried a random private facility nearby and they failed me after not seeing any cats! I didnt have any CEL/SES lights on either...
Old Apr 20, 2014 | 03:42 PM
rrt898's Avatar
rrt898
Default Inspection
If the car failed already, now you have a small problem because the state now knows. I didn't know you went already. On your paperwork it should state what failed. If you are lucky it might just say emissions. Your worse case would be install a cat every two years. I never had a garage look under my car. What made them look under your car??
Old Apr 21, 2014 | 10:58 AM
Humanoid 2.0
The cameras are in the slab, they drive over them. the images show on the computer screens they look at.
Old Apr 21, 2014 | 11:00 AM
Humanoid 2.0
seriously, you won't feel the power loss from high flow cats, you should have just got them as part of your header set up. You won't get passed inspection without them.
To NJ Private Inspection Facilities
