MA Inspection
ALL Mass inspections stations now have cameras so the state can go back and watch the inspection.
The ball joint inspection is for cars a couple of years old.
Just did my 2015 tundra guy hardly looked at anything.
The quick oil change guys have pits but still there is a small piece of metal that goes across the front of the pit and you cant get a C7 over it only C6 and older
Bill
Bill
I spoke to my neighbor who has his own shop and does stickers, he agrees all vehicles are jacked to check from wheels movement.
I'm not thrilled about jacking the car either, but will certainly help if they do it. The car is lowered on stock bolts, so only a low profile will get under there.
Good Luck.
I'll also second the notion that its all about the money...my first sticker on my brand new c7 (5 days old), they had to do all this nonsense, while the guy with a 1982 Olds, belching smoke and stinking like gas was "exempt" from the emmissions test because his car is old !???
isn't the point of the emissions test to get the dirty cars fixed and off the road ?? Why do we exempt the old ones and test the brand new ones ??
I guess my only saving grace is the shop and bay is so small, that even standing outside, I'd still be right there. Inspection bay is a single bay wide, by about 1.5 deep. I can watch and "suggest" from outside and still easily be heard.
And yes, this state sucks! We're actually looking at used Wranglers and I now have to be careful and make sure it's not more than 2" higher than stock....
Vette was no issue at all other than the parking brake didn't work as well as it should have. I asked about the aftermarket exhaust (axle back) and was told it'll be fine because "Corvette's are typically loud from the factory so it should be fine. I have the Corsa Extreme, and at idle and even under light load, it's not *that* loud. I also have tinted tail lights and side markers (a light tint film) and not a mention of it.
The car WAS jacked up to check the front end. I brought a puck with me and told the inspector I had it, and hoped he had a low profile jack as the car was low (lowered on stock bolts). He did have a super low profile jack, and used the puck as I requested. He had ME come into the bay to ensure the jack/puck was in the right spot as he didn't want to cause any damage. I only went into the bay, lined up the jack, then stepped out. Returned to do the same for the other side, and left again. No issue with me entering the bay. He finished the inspection and had me drive the car out. As I previously mentioned, it's a small garage/gas station and the inspector is a big guy. Even though he has lost about 150 pounds, he still big. I had the top down so entering and exiting was a little easier, but he still wanted to limit his use. To add, my Vette is a '99 convertible. No emissions testing since it's over 15 years old (our 2004 Jeep Wrangler was hooked up for testing). He certainly tested everything else as usual but also noticed he checked functions of seat belts too, and the gas cap. He took pictures of front and rear license plates, so those not running their front plate, put it on.
As for the Jeep, no issues other than he barked at the exhaust! It's louder than stock, but not that loud. He said it's not OEM so he can't pass it. This was before the Vette, and that's when I asked about the Vette since it wasn't OEM either, and the comment of "from the factory" came out. Like the Vette, at an idle, the Jeep isn't loud at all. Slightly louder than stock, but that's it. The Jeep also has a 2" lift and a few other aftermarket additions, all of which were no issue. I did have to raise the front plate since it was "obstructed" and couldn't be. I raised it, got it inspected (he said he'd allow the exhaust) then put the plate back down. Here's the Jeep for reference.
I have to get my 2015 BMW and 2016 vette tested.
and out of all of these, which is most likely to pollute ? (not implying yours does
