Northern California Northern California
Need alignment after lowering.
Old Mar 24, 2007 | 02:38 PM
jeff49's Avatar
jeff49
Default Need alignment after lowering.
Can anyone recommend a good alignment shop around antioch or other area. Thanks Jeff
Old Mar 24, 2007 | 02:42 PM
d3m0's Avatar
d3m0
A quick ?, How did you know it needed alignment, because I dropped mine but it doesn't sway one way when I brake and let go of the steering wheel.
Old Mar 24, 2007 | 02:49 PM
Rockdog's Avatar
Rockdog
I have been real impressed with the Les Swaab in Brentwood.
Old Mar 24, 2007 | 03:25 PM
jeff49's Avatar
jeff49
Im putting on some new tires and lowering so I thought for a piece of mine I would get an alignment. I allways get alignment with new tires. Jeff
Old Mar 24, 2007 | 03:27 PM
jeff49's Avatar
jeff49
Hey rock dog whats up, thanks for the imformation. Jeff
folsomlarry's Avatar
folsomlarry
Mark at MSI is Roseville is an alignment specialist if you want a good shop that is a little out of your area.
Larry
Old Mar 24, 2007 | 03:50 PM
White99FRC's Avatar
White99FRC
Larry
or if you are in the Bay Area, Roger Krause Racing in Castro Valley, CA.
Old Mar 24, 2007 | 04:00 PM
MEANZ06's Avatar
MEANZ06
Old Mar 24, 2007 | 04:56 PM
StArrow68's Avatar
StArrow68
Mark at MSI is great if you want to go that way and Brendon at Krause
is very good as well. I had a local shop do mine after 3 years and he
noted that stock alignment isn't always too precise, some are surprised
at how wide the stock spec can be. Also, the local shops I've talked to
didn't have a clue beyond what was in the spec book. If you want to
understand how to make it handle better, get a pro who knows the
Vette.
Randy
Old Mar 24, 2007 | 08:13 PM
1998 GTR's Avatar
1998 GTR
Had mine aligned and corner-weighted at Krause racing. They did a great job! Brandon Krause does all the alignments - He knows his stuff! . . . AND he knows Vettes!
Dave
Old Mar 26, 2007 | 07:42 PM
C5stein's Avatar
0C5stein
Former Vendor
I do over 300 Corvette alignments each year and offer corner weighting for the racers as well. I've been doing CWs and Alignments since 1980 when I started racing.
Give us a call and we will be happy to assist you.
Old Mar 26, 2007 | 10:34 PM
SLPRC5's Avatar
SLPRC5
Larry
worth the drive
To Need alignment after lowering.
