FS: LS2 Intake Manifolds...
Former Vendor
I have three manifolds sitting in stock. Asking 150.00 Each OBO.
Rick
Rick
Former Vendor
http://www.hotrod.com/techarticles/1.../cam_swap.html
The LS2 manifold, despite it's 90mm TB makes less power than a LS6.
-TJ
Originally Posted by Hot Rod Dyno Test
There's been a lot of speculation on the Internet that swapping the LS2's intake manifold with its large 90mm throttle-body might be a hot-ticket setup for older LS1s. Testing that theory, we back-to-back tested the LS2 manifold to an '04 LS6 manifold with its smaller 76mm throttle-body, which is also Drive by Wire. The result: the LS6 design outdistanced the newer LS2 by 8 hp and a huge 16 lb-ft of torque. All the LS1 guys out there scrambling to buy LS2 intakes from dealers might want to reconsider, but if you have a new Corvette, maybe you can trade your intake to someone with an LS6 manifold before he reads this.
-TJ
