Northern California Northern California
Broken Studs
Old Jun 25, 2008 | 06:45 PM
tjea's Avatar
tjea
Default Broken Studs
Any body had broken studs on rear wheels. I just had a stud replaced on each rear wheel. dealer said they had never seen that before. A little scary.
Old Jun 25, 2008 | 06:52 PM
C5'S LS1's Avatar
C5'S LS1
I thought I was going to snap one the other day.
Good thing the rachet extention broke first, actually 3 extentions. Then that sucker came off.
Old Jun 25, 2008 | 07:04 PM
SLPRC5's Avatar
SLPRC5
They are only torqued to 100flbs....my 8 yr old grandson can break em lose...well almost
Old Jun 25, 2008 | 07:05 PM
Sidney004's Avatar
Sidney004
Overtorqued?
Old Jun 25, 2008 | 07:20 PM
1989vette's Avatar
1989vette
Wait for rich to chime on in...i'm sure if its been done he's seen it or knows about it
Old Jun 25, 2008 | 07:22 PM
Steve@RSD's Avatar
Steve@RSD
St. Jude Donor '13
Track day with lots of heat will temper them. You have to make certain not to overtighten them cold, the wheel could grow and snap them. Loose can also do that but they would all be loose.
Old Jun 25, 2008 | 07:26 PM
SLPRC5's Avatar
SLPRC5
Excellent point
Old Jun 25, 2008 | 07:34 PM
Wicked_Z06's Avatar
Wicked_Z06
I do 100 as well.. factory specs.
Old Jun 25, 2008 | 08:22 PM
Just Enough's Avatar
Just Enough
If you are heat tempering your wheel studs your bearing grease would be on fire. Broken studs are usually due to corrosion in the valleys of the threads which causes a stress riser and then cracks through when overtightened or overtightened and then the aluminum wheel expands from heating up and pushes the stress over the limit. I have been lightly greasing my wheel studs for 30 years to eliminate the corrosion issue along with getting equal clamping force on all five studs from the applied torque.
Old Jun 25, 2008 | 08:26 PM
SLV-N-BLK's Avatar
SLV-N-BLK
St. Jude Donor '08
WTF!!!
I just check myself and I'm still in on peace, what are you guys talking about.
Old Jun 25, 2008 | 08:33 PM
Z064FUN's Avatar
Z064FUN
Originally Posted by SLV-N-BLK
WTF!!!
Old Jun 25, 2008 | 08:36 PM
SLV-N-BLK's Avatar
SLV-N-BLK
St. Jude Donor '08
Originally Posted by Z064FUN
Someone had to do it. Well maybe not.
Old Jun 25, 2008 | 09:25 PM
Z064FUN's Avatar
Z064FUN
Yea, I was kinda waiting for it
Old Jun 25, 2008 | 10:50 PM
Miguels's Avatar
Miguels
WTF!!!
yeah, but we are not talking about Broke Back Studs....that's for the BAR thread..
Old Jun 26, 2008 | 12:11 AM
SLV-N-BLK's Avatar
SLV-N-BLK
St. Jude Donor '08
Leave Gorge out of this.
Old Jun 26, 2008 | 12:17 AM
Steve@RSD's Avatar
Steve@RSD
St. Jude Donor '13
My father tells the story of having lubed his studs as well and later having to hike off the road to retrieve the wheel that came off. Nobody will every convince me to lube that thread. I will however give them a once over with a wire brush whenever I have the wheels off to make sure the clamping force is equal on all the studs. I have already wasted one set of bearings on my left rear from heat, I know it can happen.
Good luck with those greased wheel studs!
Steve
Old Jun 26, 2008 | 09:10 AM
Just Enough
Steve
If you are cooking the wheel bearings you are approaching the steel tempering temperatures 400-700 degrees F. Cleaning your threads is wise. As I stated I have been lightly greasing mine for 30 years with no loss of wheels yet, I must add that I always use a torque wrench. Lubed bolts and nuts don't come loose, improperly tightened ones do. Head bolts and nuts are lubed and don't come loose. I know that lubing a wheel stud makes people cringe, I can't help them with what they believe or do with their studs, I am just adding to the discussion what I have done with mine.
To Broken Studs
Old Jun 26, 2008 | 10:12 AM
briann510's Avatar
briann510
Ive had properly torqued nuts come loose on lubed studs before. I never lube a wheel stud anymore. Not sure why they came loose though but sure convinced me never to do it again.
Old Jun 26, 2008 | 10:29 AM
C6 Fitz's Avatar
C6 Fitz
Never-Seez
Old Jun 26, 2008 | 10:32 AM
C5'S LS1's Avatar
C5'S LS1
Originally Posted by C6 Fitz
Never-Seez
Yeah, I broke my cheap torque wrench awhile back, so I probably, previously, had that one on too tight.
