Northern California Northern California
Alignment
Old Sep 11, 2008 | 10:31 AM
RedSSR's Avatar
RedSSR
St. Jude Donor '08
Default Alignment
I went to Roger Kraus yesterday and got an alignment done by Brandon. I am very happy with the way the alignment was done. Very precise and done by someone with 20 years of experience. Brandon even took the time to readjust the steering wheel position when he was all done because it was off very slightly. They have an excellent laser alignment machine and a ton of experience aligning cars like ours. If you need an alignment and want one of the best jobs around go to Roger Kraus in Castro Valley and make an appointment with Brandon.
Old Sep 11, 2008 | 10:56 AM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
What specs did you have them align it to Lonnie?
Old Sep 11, 2008 | 12:42 PM
RedSSR's Avatar
RedSSR
St. Jude Donor '08
It is a big secret and I will not tell anyone., Just kidding, I will get the sheet out of the car later and let you know. I did not go with the aggressive track alignment I have done in the past. I did do a pretty aggressive street alignment though. Camber in the front is now very visible.
Old Sep 11, 2008 | 03:02 PM
exz06ic's Avatar
exz06ic
Congrats.... You got to love Roger Kraus (Brandon) it might cost a little more but well worth it and you know it will be done write the first time.
Lonnie - Did you have him align it with the 20's or the HRE or the Z06 stock wheels?
Old Sep 11, 2008 | 03:13 PM
EVILNESS's Avatar
EVILNESS
I need mine done how much???
R.
Old Sep 11, 2008 | 03:27 PM
RedSSR's Avatar
RedSSR
St. Jude Donor '08
I had it aligned with the 20s on. I have been a long time customer of theirs and get better than public pricing. I believe the going rate for a car with coil overs is $180. You may be able to negotiate better pricing.
I watched Brandon's video of his incident at T-Hill, I will be thinking twice about driving 8/10ths, 9/10ths out there. I will be pretty careful out there.
Old Sep 11, 2008 | 07:09 PM
Z51JEFF's Avatar
Z51JEFF
Next time,if your real lucky maybe they can put the lift UNDER the floor pan.This place sucks.
Old Sep 11, 2008 | 08:00 PM
RedSSR's Avatar
RedSSR
St. Jude Donor '08
What happened?
Old Sep 12, 2008 | 10:58 AM
Z51JEFF's Avatar
Z51JEFF
What happened?
I took my 84 there years ago to get the car lowered,the cars were so new back then nobody knew how to lowered them so I asked around and somebody mentions the above.Get the work done no problem.Several months later Im under the car changing the oil and find both sides of the floor were caved in were some hack missed the frame and lifted the car with the lift under the floor pan.Right after buying this car I put up in the air to get a look underneath and this damage wasnt there.I call the place,take the car down there and the owner comes out to look at the car with some derelict lookin dude.Both guys get down to look at the damage and the look the owner gave the other moron said it all.None the less,owner denied responsibility.Its been close to 20 years since this happened and I still get pi$$ed when I think about it.This place will never touch any of my cars.And they put a piece of LEATHER between the spring and frame to ,squeaked like you wouldnt believe.
Old Sep 12, 2008 | 11:06 AM
RichieRichZ06
St. Jude Donor '08
Did you get a peek at the specs yet? I am curious waht you put them at.
Are you running T-Hill on the 26th?
Old Sep 12, 2008 | 11:14 AM
RedSSR's Avatar
RedSSR
St. Jude Donor '08
Yes, I will be up there on the 26th. What run group do you get to go in by using Charlie's spot? Here is what I had:
Old Sep 12, 2008 | 11:21 AM
RedSSR's Avatar
RedSSR
St. Jude Donor '08
Sorry to hear about that. I have had numerous cars here over the past 9 years and have had no issues. I hang out while alignments are done and other work and like the way they operate. I had my C5 Z06 aligned at least 6 different times there and have had them get me around 4 sets of rubber for that car alone. A lot of racers use these guys and wouldn't if they did not know what they were doing. Anyway again sorry to hear about your car.
Lonnie
RichieRichZ06
St. Jude Donor '08
Nice, I think you will like the feel of it on the track. On the Hoosiers, they advice you to run more camber then that, but try it and see how you like it. So far, they signed me up for 1 because that is where Charlie was, but they said they will move me up accordingly. I ASSume that I will be in 3 or 4 quickly. I can't do the whole "no open passing" thing.
Old Sep 12, 2008 | 11:23 AM
Sidney004's Avatar
Sidney004
Its been close to 20 years since this happened ....
and I thought only my wife had a memory for details like that!
Old Sep 12, 2008 | 11:33 AM
RedSSR's Avatar
RedSSR
St. Jude Donor '08
Sidney, are you going up on the 26th?
Old Sep 12, 2008 | 11:39 AM
RedSSR's Avatar
RedSSR
St. Jude Donor '08
I know but I am still driving around with 20s and Michelin PS2s. So I didn't want to wear the inside of these tires out while I drive around for the next couple of weeks. Also with a lot of camber and 20s on the front you have to watch out for bending the inside lip of those wheels on a pothole where all of the force would be located.
Anyway I thought it was a good compromise. No prizes or awards for the fastest laps this time. I will be driving pretty conservatively and safely in the open group. Probably still pretty fast I would guess though.
Old Sep 12, 2008 | 06:33 PM
Sidney004's Avatar
Sidney004
No, I wish I could; I am going to Thunderhill on Oct. 8 with these guys:
http://www.yourprivatetrackday.com/events.aspx
It is more expensive, but you get a ton and a half of track time. I think they still have a couple of slots open. It is right before the HOD "All Corvette" day though.
Old Sep 13, 2008 | 02:04 AM
EPiC Vette's Avatar
EPiC Vette
Last I talked to Ric, they were filled up. It never hurts to try, though!
Phil and Ric put on a great track day. Even running Advanced (middle group), you can get more than 3 hours of track time.
To Alignment
