FS: Intercomp USA made top level motorsport aligment equipment - USA MADE NEW
1 x pair Digital turn plates (p/n 102191)
0.1° Increments
2,000lb Capacity
Set of Two
Measure Wheel Angle with the Industry's First Digital Turn Plate
Multiple Direction X & Y Movement
High-Strength Bearings
Large, Easy-to-Read Electronic Display
0.1° Graduation
Range of ±30° (60° Total)
Light-Weight Aluminum Construction
Take Several Easy Measurements to be Used for Alignment. Including Caster/Camber & Ackerman
Can be Placed on Top of Scale Pads
Standard 9-Volt Battery Operation
Dimensions: 13" x 15" x 1.625" (330 x 380 x 41mm)
1 x pair turn plate rear aluminum spacers (p/n: 100339-09)
Features:
Maintain Proper Weight Distribution by Keeping the Rear Level with the Front Plates
Constructed from Light-Weight, Aerospace-Grade, Aluminum
1 x Digital camber caster gauge with magnetic adapter and carry case (p/n: 100005)
Features:
Indicates to 1/10° & has a ±20° Caster/Camber Reading
Selectable 15° or 20° Caster/Camber Reading
Up To 10 Times Greater Accuracy than Traditional Bubble Gauges
Standard 9-Volt Battery Gives Up to 100 Hours of Operation
Lightweight, Aluminum Design with Auto Shut-Off & Backlight
Inclinometer Mode for Pinion & Strut Angles
Built-in Diagnostic Mode for Resetting Camber Zero
1 x RIM CLAMP - AUTO (13 to 18"/330 to 457mm) (p/n: 100007)
Asking $2,200 for all brand new, unused equipment - located in SF, Bay Area (Norcal)
0.1° Increments
2,000lb Capacity
Set of Two
0.1° Graduation
Features:
Features:
