FS: customized LS3 FRCs
SOLD
LS3 Modified FRCs professionally painted gloss black and has red embossed vinyl lettering
The bottom part of the cover was cut at the horizontal line to show off the coils. As an added benefit the coils no longer will get heat soaked from being covered. The foam pad underneath or the hold down grommets are not included, you can use the ones from your set.
