F350 Tranny fluid
F350 Tranny fluid
Checked my tranny fluid this weekend during the oil change, finger came out of the fill hole with red fluid. It's a 6 speed manual tranny, and unless they started putting red dye in gear lube, the stealership put ATF in the tranny Should I drain it n refill with gear lube or leave it as is?
