escalade tire monitors
i put 2007 escalade wheels and tires with monitors on my 2005 escalade..anybody done this before or know what i do to re program the monitors,,im getting a service tire monitors,,,,,thanks tony
Won't get much help in "C5 general". If its the same as the C5, then there is a DIC re-learn write-up using a magnet on the sensor.
Otherwise, go to "other cars" forum
Well Caddy or Vette I would think '07 and '05 may be different TPS Systems. You might get a better answer from C6 General.
I swap wheels each Fall and Spring, and if your Escalade is like my 04, you calibrate the TPS by letting 2-3lbs of air out of LF, RF, RR, & LR in that order (I think). I believe it is outlined in the manual.
Try www.cadillacforum.com.
