Other Cars Non-Corvette Content, Daily Drivers, Winter Beaters, Work Trucks, Tow Vehicles, for sale
Massive Power
Old Jul 7, 2007 | 03:13 AM
RedBeauty84ZX's Avatar
RedBeauty84ZX
Default Massive Power
http://youtube.com/watch?v=6csnoENeNOA
"As most of you know an inertial dyno calculates power based on the amount of time it takes to spin the heavy drum. An NA for instance takes nearly 10 seconds to do a dyno pull to redline. Most upgraded TT's still take several seconds. Notice the amount of time it takes the car to spin up the roller and complete the pulls once the throttle is applied. The engine is being taken up to over 8,000 rpm during the pulls. It made 880 rwhp at 36 psi (Z1 GT725R kit) without any nitrous on the pull before that. Then we sprayed it. We were unable to get a reading using the nitrous, because of a lack of traction. The tires were just spinning on the roller even with it strapped as tight as we could get and with some extra weight in the trunk on the second pull. We were spraying both stages in that video (on top of the 36 psi). The initial shot is a 60 shot mounted in the hardpipes before the throttle bodies. The second stage is a 225 direct port shot mounted under the lower plenum. The car was almost certainly producing over 1200 hp at the rear wheels on those pulls (considering the multiplying effect of nitrous on a turbo car). "
With Smaller turbos and less Nitrous the car dynoed at 1051RWHP a few years ago. With the new setup its likely making 1250+RWHP.
