Ok, seems that one of my mechanics (my oil change mechanic) some time ago changed the diff fluid in my 06 Tundra and now I am getting this buzzing sound. They said it should be fixed with a thicker diff fluid, but considering it didnt buzz before them, I dont think I want to let them touch it again.
So I think I am going to do this myself.
Just curious what is the thickest diff fluid you can put into a 06 Tundra.
Crawl under your truck and check the diff.cover for a sticker that should say LSD FLUID ONLY.Most Tundra's came with lsd's and i'm betting he didn't add the proper additive to quiet the clutchpacks in the diff.
Let me know if this is the case.
Ok,no sticker.It might have been pulled off.But none the less 80W90 is about as thick as you can go.I would still add a bottle of lsd additive especially if its a TRD model.Three things when doing the change,loosen the top fill plug and let some air in the case as it will flow out faster when you drop the drainplug.Also check both backing plates for wetness as sometimes the axle seals do leak.Third make sure the vent breather cap for the diff is not clogged it should move freely on its top cover.
awesome thanks.
hopefully this will cure the buzzing/ rubbing sound i have
Extremely thick stuff,we don't use that at the dealership at all.If you live in a cold climate that stuff will be like cement until it warms up.Really should try a lesser weight.
i live in the deep south.
usually runs 70 degrees here lately and will get up to 100s in the summer.
plus i usually drive my truck on the highway for about an hour an a half at about 85- (well lets just say higher then 85)
You think thats too much, cause they did have an 85w90 but remember i am trying to kill a buzzing or rubbing sound that speed related
Also, I just crawled under to look at the setup again. It has the following that I am not sure about so I figured maybe you can help me.
There appears to be what looks like a tire air valve on the very top of the diff case that has a cover over it, what is that for? do I need to bleed the air out?
That is the diff. breather I mentioned earlier.Make sure the cap on it moves freely from its base and not clogged.If clogged clean out the dirt with brake clean and tap out the dirt lightly with a small hammer.
Ok,at this point it needs to be safely hoisted in the air in drive to see if the noise is coming from the ring gear area or a hub bearing.Also check your driveshaft u-joints for play with the transmission in neutral.The driveshaft itself has several grease fittings in the joints and the slip-yoke of the shaft itself.
Had my Yota delaer look at it, and what they did I dunno, but they stated it needs a new rear end.
