Impala window replacement
Took the car home and tore the door apart but can't really get inside the inner door frame to the linkages. Seems like a cable broke free completey in there. I can push the window up and down manually but the motor won't work. So, took the car over and dropped it off today to include fixing the window.
Question: do any of you guys know if this linkage can be fixed given its inaccessibility or is a whole door replaced? I hope not but the access to the inner door cavity is so limited I don't see how much work can be done in there.
