Other Cars Non-Corvette Content, Daily Drivers, Winter Beaters, Work Trucks, Tow Vehicles, for sale
Syncronizing two engines
Old Dec 1, 2019 | 12:59 AM
ncali's Avatar
ncali
Default Syncronizing two engines
How would one sync up two v-8 engines sitting side by side in a frame with one output
like a tractor in a tractor pull comp. and they use up to 4
Old Dec 1, 2019 | 01:48 AM
Moved to Other Cars.
Old Dec 3, 2019 | 09:45 AM
FourFather's Avatar
FourFather
St. Jude Donor '08 thru '17,'22
I ran a clutch, driveshaft, and ring and pinion from each engine, to a one piece, 3 inch diameter tubing, rear axle, with the ring gears bolted solid to flanges on the axle. So the engines did not have to be synchronized. I could run each engine separately. Both clutches were hooked up to one clutch pedal, normally, to race the car. But I could disengage one clutch by releasing both with the pedal, and then putting a pin in one throwout bearing linkage to keep that clutch released, and then make a run on the other engine.
Old Dec 6, 2019 | 09:36 AM
ZEN357's Avatar
ZEN357
I don't know what you are planning here..... but take my money.
To Syncronizing two engines
