Other Country Events Other Countries
wheel studs
Old Apr 21, 2002 | 02:34 AM
LATNC3's Avatar
LATNC3
Default wheel studs
darcy, the racing studs i put in the hubs of my '81 were 7/16 ARP, jegs P/N 070-100-7701. they are 2-7/8" long, with a .580 diameter knurl. just beware: unless you have the rear hubs disassembled or have already removed the brake shield, you will not be able to get them in. i had to cut my brake shield and gut the 'emergency brake' (yeah, like that thing ever worked ). once i got them in, i put a small tack weld on them since they were such a pain to get to. also, you will need different lugs if you ever want to run the aluminum wheels i'm assuming your car came with.
Old Apr 21, 2002 | 12:15 PM
Magnet's Avatar
Magnet
Default Re: wheel studs (Rod Rodriguez)
Rod...Thanks do much...your brilliant!!!!! :eek:
