Balancer install by Jonathan...
Hi All,
Just had Jonathan work on my car yesterday and I have to tell all of you how hard this guy works. He does a quality job at an economical price, and his resume http://forums.corvetteforum.com/paci...new-place.html is right on target.
It's really rare these days to see someone at his age (25 YO) with such talent and drive. I know they're out there and he's one of them.
Thanks again Jonathan,
Don Thorne
Don Thorne
good to hear Jonathan was able to help you (and himself) out!
my balancer wobbles just the tiniest teensy weensy bit. thinking i should get it done soon. better safe than sorry!
jeff
jeff
Great everything worked out for the both of you. I must say, I think alot of LS motored balancers wobble, mine has for 70k never been an issue. I called Tom on it when I first found it, he said the same thing, alot do it but most are never a problem. I will say if it wobbled alot, I would fix it. That may have been the case here.
Don
We used:
SUM C2503 Balancer, 25% underdrive.
GTR 4060780 Belt, Gator-Back.
ARP 234-2503 Bolt & Washer, LS1 - LS6
Also replaced Belt Tensioner & Pulley Idlers from Gene Culley (GM Parts House). Hope I got that right?
All from Summit... The balancer is Summit Private Label, looks just like a "SPL".
Hope that helps,
Don
Hope that helps,
Don
We used:
Hope that helps,
Don
Hope that helps,
Don
Summit Balancer
Oh, side note: Along with this UD Pulley I also have an aluminum Fly Wheel with a performance clutch and with that combo the engine now picks up RPM really fast.
Hope this helps and good luck,
Don
Oh maybe a little over 5000. And no track time. We just enjoy the road trips but also like the added performance. I also added LG Long Tubes, X pipe and axle back mod. along with cold air intake. And it still gets as much as 33 MPG on the open road.
The car is 12 years old with over 100k on the clock and me at 65 YO... Well let's just say we're both feeling our age.
But I still need a Hot Rod.
Don
Don
