Alignment
I just put new front tires on my '06 coupe. I got 35,000 miles out of the stock GS2's but I could have gotten more since they wore more heavily on the inside edges (standard for the factory alignment as I understand). My intention is to get a more neutral alignment so the fronts wear more evenly on this set of tires.
My question is, do I need a race shop (and race shop prices) to accomplish this or can a more run-of-the-mill shop do just as good a job? Will a regular alignment shop get very close to a particular spec (I've run across neutral Pfadt specs on the Forum) or will they just stop at being within wide tolerances like the factory spec?
Also, what should I expect to pay for the type of alignment I'm looking for?
Any other recommendations for good shops in the Bremerton/Port Orchard/Poulsbo/Olympia/Tacoma/Seattle/Eastside areas would be appreciated.
If you were in the Portland area, I would recommend A N T Tires. They have done all of my alignments. I don't know anyone in your area to recommend.
FWIW, I get really even wear on my track tires since having a proper alignment.
Front
Camber -0.8deg
Caster 8.0deg
Toe 0.0in
Rear
Camber -0.5deg
Toe 0.0in
Is there some particular skill in aligning the car to these specs or is it just a matter of the shop being willing to take the time to get to the spec rather than just within some rather large tolerances one way or the other?
I have to disagree with the alignment specs you posted. Way too much neg camber for good tire wear. FWIW, the general recommendation has been get the camber down to -.2 or even -.1. In other words, for best tire life, get the tire rolling as flat as possible but keep some neg camber for handling.
Some reference threads for your enjoyment:
http://forums.corvetteforum.com/c6-c...alignment.html
http://forums.corvetteforum.com/c6-c...tire-wear.html
I don't know about Rick T. but I pretty much drive my car like any other street car 99% of the time. I'm not pushing it hard around corners.
Maybe this is the reason for the very broad tolerances on the factory specs....because driving styles can be so different which dictates widely different settings. But if that were the case why wouldn't there be different settings for different drivers (somewhat like Pfadt) rather than just huge tolerances?
At any rate, I'm still up in the air as to the "right" settings to use for what I'll call sedate street driving and even tire wear.
Any bit of toe out on the street will wear the inside shoulder of the tire, but if you look at the tire 1-2" in, its worn the same as the outer edge. THAT is a toe problem (which can be exacerbated by "excess" caster).
Even with 0 toe on these cars will get you there, you need a slight bit of toe in. Thats because with the compliance in the suspension, it tends to goto toe out dynamically, which then gives the wear.
Try 1/8" toe in on the in front, and whatever camber you want to run with as long as its at least -.5deg. Set the caster in the mid point of the adjustment range that you can, too little will make the car nervous, and too much will help whack that inside edge. In the rear go for the same -.5deg and 1/8" toe in, more toe will plant the rear better, at the cost of tire wear, so keep the rear toe as minimal as possible while still allowing for compliance, and keeping the back end from wanting to swap ends.
People spend too much time worrying about having the perfect camber setup, but often ignore the other adjustments, and then, only look at them statically, you need to setup the car while keeping in mind what the suspension is doing with the wheel while you're moving.
Thanks again.
