After about 500 miles, the one thing that bothers me most is the tire roar from these GS2's. The Corvette is supposed to be a road trip car for the missus and I, but on concrete surfaces, the noise is really irritating. I'd love to replace the tires but that would eat into my mod (and gas) money. . . I'll try and use up the tread as soon as I can!
So, I'm either looking for experiences people have had with local shops (Bellevue/Redmond preferably) installing a full interior soundproofing, either using one of the forum vendor supplied kits or custom cutting materials of their own, or possibly putting together a day- or weekend-long do-it-ourselves insulation installation party using forum vendor supplied kits.
Thanks.
If you really want it quite you are in for some work. The first thing to do is educate yourself. While the form kits help they will not make the car what I would call quite. Check this link out:
This is the product I have used in my last 3 cars. It is just not all dynomat, foam or whatever. You need different material for each unique application. This is not hard to do on our cars about 3 days to do it right. And it will cost you north of $500. The other thing to remember if you do this is to get all the fasteners for the interior. They will be destroyed taking them out.
My son in law and I took my 2008 ZO6 apart and installed insulation in the floor boards, tunnel, behind the seats and the cargo deck. We used duct insulation we bought at home depot instead of dyna-mat. the duct insulation is aluminum on one side with 1/4 of adhesive foam on the other. I noticed a significant difference after we were done. Took us about 2 hrs to remove the seats, console, and all of the carpeting, and about 4 hours to install the insulation, and 1 1/2 hours to reinstall everything. All said I spent about $200.00 in materials. It's not a bad weekend job as long as you take your time, and it definitely helps to have someone to help you. Send me a PM with your email address and I'll forward what I have to you.
By the way I just changed wheels and tires to 19s on the front and 20s on the rear with Continental Direct Contact DW tires, and the sound difference was significant.
Thanks for that link - I think I've seen that before and it is a good one. I'm not looking for for a supremely quiet interior, but there is a lot of tire roar and the center console gets pretty warm. Right now, the console is the bigger issue. If I can get that cooled down and reduce some of the tire roar, I'll survive until I burn these tires up and replace them with something quieter. I also don't want to add a lot of weight, and I thought that some of the better soundproofing materials worked by adding mass. How much weight did your insulation add to your Corvette?
Personally, I'm also not opposed to paying several hundred dollars (up to maybe a thousand or so) for a good shop to do this for me if the weight isn't too extreme and the results are going to be significantly better than the precut vendor kits.
I'm pretty sure with the right amount of pizza and beer you could get a few people to help you out on that install...
I tore mine completely apart and used a Dynomat like material- I put 2 layers on, off setting any joints. I then bought a tunnel renforcement plate with the thermal abs option.The 2 layers did not help the console heat but the tunnel plate did.
I took a 2500 mile road trip and it did quiet it a bit but it's a convertible and still has road noise just not the heat.
If I'm getting help doing the install, there'll be way more than just pizza. I'm thinking some nice steaks, maybe some salmon on a BBQ. Gotta treat the help nicely!
I'm pretty lazy but am honestly hoping to get a few folks together to do this. I think a forum vendor kit would be enough for me, and since most of the tire roar comes from the rear, I could always throw a block-it mat down on top if it still is a problem, and then live with it that way until I get new tires.
Ok, so I'll ask. Are you offering to help? I'd be more than happy to make it worth your while!
I did it in my C5. It adds almost no weight. I mean, what does a roll of Frost King and a roll of duct tape weight anyway? 2 pounds? It made a big difference.
Then I swapped the GoodYears for Michelins and it was niiiiice and quiet.
Dynamat works better, sure , but yes it does add more weight.
So I was at the Home Depot today and looked at the Frost King, and it's like the regular fiberglass wall insulation with aluminum backing. I thought for some reason that it was like a dense bubble wrap with aluminum backing. Sox-Fan, what kind of Frost King did you use?
I did the area behind the seats with the Frost King like stuff from a Forum Vendor. It made about 1 db difference, so I stopped there.
Yes, I don't like the tire roar, and when I wear out the tires I will probably get a set of Michelin PS2s.
But for now it is tolerable for me. If you want a hand with tearing out the car apart, I'm sure there will be some folks willing to help. But first, take your time and talk to some knowledgeable folks. There is a Corvette gathering next Saturday, and I'd be happy to check if they can handle one (or two more). You'll be able to ask a lot of questions, and get answers.
I put the car on stands, took off the rear wheels, dropped the plastic wheel well inserts, sound proofed in there and put the inserts back. That made the bigest difference by far. I then did the area inside the hatch around the wheel wells and was pleased with the results.
I still have most of a roll left. COme on up here to Sammamish tomorrow, I'll give it to you.
Super appreciate the offer, but only if you'll let me pay you for it. I'm available all day today, will be heading out in a moment to go to Harbor Freight, then to work out with my son. I'm available any time after 4:30 p.m. and would love another reason to cruise in the Corvette.
Send me a PM it that works for you, and I'll check it as soon as I'm back home.
I'm really wanting to make the Saturday gathering, but that is the day when my wife and I go over to visit our Mom's, and that's a hard thing to get out of. Maybe I can swing a deal to be available, but it's already quite a large gathering and I don't want to contribute to any overcrowding!
I'd also volunteer my place for the installation since I've got a three car garage, but it's STEEP and I think there's only one garage that we could get a Corvette into without damage and it's not the middle garage. I definitely envy your garage and driveway!
Wayne,
I understand family commitments. There will be other gatherings I'm sure.
I'm not sure how much improvement you'll see with the addition of insulation on the inside of the car. As it is, your car has the Goodyear F1 tires (correct?) which are a bit less stiff than the Supercar tires that come on the GS and Z06s. So I would expect they should be a bit cushier and quieter. There other tires that are supposed to be quieter, but I have no experience with them.
My suspicion is that if you insulate the upright area directly behind the seats and then take out the rear wheel inner housings and insulate behind there, that you'll get the most bang for the buck.
The problem is the stiff sidewalls of the runflat tires help to transmit noise from the lousy roads, but contribute to the responsiveness of the car too. I just haven't heard of anything that really solves the problem.
Thanks!
I wouldn't even know what to charge you. It has been sitting in my garage for 4 years now. I'm happy just to see someone put it to use. I'll PM you with my number.
