Pacific Northwest Idaho | Oregon | Washington | Hawaii | Alaska.
Storage
Old Feb 12, 2013 | 09:26 PM
SL1D3R's Avatar
SL1D3R
WA Events Coordinator
Default Storage
Does anybody have room for a C5 on their property?
Thought I'd ask.
The real question is:
While the car is sitting, can I simply unhook the battery to maximize battery life and minimize power drain?
I'll be flying down to Arizona on Sunday for the foreseeable future. I'm not sure if I'll come back for the Vette or sell it.
Until I know for certain, I would like to keep the battery in a working condition.
Old Feb 12, 2013 | 09:28 PM
c4cruiser's Avatar
c4cruiser
Definitely disconnect the battery.
Old Feb 13, 2013 | 06:51 PM
Lead Foot 66's Avatar
Lead Foot 66
And put the battery on a tender to keep it up if you're going be have it out for more than a couple of months. If the battery is already rather long in tooth, you may just wish to buy a new one when you get back.
Also, if you are contemplating storing it for 6 months+,add Gas stabilizer such as Stabil and then fill the gas tank, change the oil/filter so you have fresh oil in it while it is sitting, pump the tires up to max pressure (to minimize flat spotting), give it a fresh wax job and cover it while it is stored in a garage.
Then, upon start-up, pull the fuel pump fuse and crank the engine over in several short bursts to get oil circulating before you replace the fuse and start it up.
Good luck with whatever you're doing in AZ!
Old Feb 13, 2013 | 09:14 PM
SL1D3R's Avatar
SL1D3R
Wow.
That's a lot.
I'm hoping that I won't have to leave it for more than a month.
Thanks.
Old Feb 14, 2013 | 10:07 AM
Kmcoldcars's Avatar
Kmcoldcars
I have a totally enclosed carport that I could keep the car in for a month or two. PM me for details if interested. I am in Puyallup. Keith
Old Feb 15, 2013 | 11:33 PM
Lead Foot 66
Originally Posted by SL1D3R
Wow.
That's a lot.
Thanks.
If you're only going to have it stored for a month, all you should need to do is pull the battery and get it on a tender. I store mine for ~ 4 months, so a bit more is required.
To Storage
