Paint/Body Corvette Materials, Techniques, and How To
How much Bonding Adhesive do I need
Old Feb 26, 2007 | 01:18 PM
kortensi's Avatar
kortensi
Default How much Bonding Adhesive do I need
I was wondering,
How much Bonding Adhesive do I need...
to reattach the Firewall and Front Clip.
Also, is the Eckler's adhesive the best or is there a better one out there?
KO
Old Feb 26, 2007 | 01:21 PM
clive's Avatar
clive
I have used Fusor by Lord's. It comes in two attacked tubes that uses a special caulking gun. It is used for new vehicle construction and it is VERY strong. I am sure others will agree. I bonded my rocker channels in with it. Just a small bead will do.
Old Feb 26, 2007 | 01:39 PM
SLVRSHRK's Avatar
SLVRSHRK
I used Fusor on my header bar replacement. Good stuff. Needed less than a tube to do the whole thing.
Old Feb 26, 2007 | 05:46 PM
Artsvette73's Avatar
Artsvette73
If you are going to bond the front clip to the car with fusor I would get at least two tubes. This is one job you don't want to end up short. Also fusor comes in diffrent setup time slow cure and fast. Just take your time and fit everything first. Go to www.lordcorp.com look at adhesives and coatings
Old Feb 26, 2007 | 05:49 PM
noonie's Avatar
noonie
The best type EPOXY
Old Feb 26, 2007 | 08:06 PM
rponfick's Avatar
rponfick
The Eckler's and Vette Bond II set up much too quickly for the occasional time users, on the range of 5 -10 minutes depending on temperature and mixture ratios. The Fusor and 3M brands offer up to an hour. For me, it was near impossible to get everything lined up properly in the short time frame.
Just my experience on two front clips.
Ralph.
Old Feb 26, 2007 | 08:14 PM
JustForFun's Avatar
JustForFun
what number of adhesive would one want to install a clip?
looked like there were 8-10 choices
Old Feb 26, 2007 | 08:16 PM
SLVRSHRK's Avatar
SLVRSHRK
Call their tech support line, they are very knowlegeable.
Old Feb 26, 2007 | 08:18 PM
JustForFun's Avatar
JustForFun
I didnt even notice a phone number. Ill look again. thanks
Old Feb 26, 2007 | 08:34 PM
rponfick's Avatar
rponfick
I used Fusor 127EZ, which has about 1 hour set up time. My paint shop always loans me the special caulk gun you need to install the stuff.
Ralph.
Old Feb 26, 2007 | 11:28 PM
VETTEVIC's Avatar
VETTEVIC
Ralph.
Thats the one to use
Old Feb 27, 2007 | 06:18 AM
Hippiehead025's Avatar
Hippiehead025
Dont use that crap from ecklers... use 8219 from 3m. Its afiberglass/ smc glue. Itsv ery nice stuff and lasts, and application is very nice when you use the gun for it. you have about 45 minutes to work with it in nice conditions with little humidity. Its all i ever use on restos and/or anything fiberglass. - Roger
Old Feb 27, 2007 | 10:28 AM
my58's Avatar
my58
you can get an aftermarket gun for the 3m adhesive that works as well as the 3m at
http://www.autobodytoolmart.com/p-10...artridges.aspx
Old Mar 2, 2007 | 11:56 AM
dennis's Avatar
dennis
This worked great for me. The gun will set you back.
http://www.nortonautomotive.com/Data...00000000001795
Old Mar 3, 2007 | 08:04 PM
ikwhite's Avatar
ikwhite
Default Lord fusor
http://www.lordfulfillment.com/upload/DS3374.pdf
This is the stuff I am looking at using a two part Lord Fusor 310 A/B Thixotropic Epoxy that you can mix up to suit your needs and can get in larger quantities for the bigger projects like firewall etc.. that I too will be tackling . Anybody here use this one ?
Ikwhite
Old Mar 3, 2007 | 08:42 PM
rponfick's Avatar
rponfick
I used the Fusor 127EZ to bond on my front clips. I am not familiar with the product you mentioned. It almost appears they make too many products to confuse us.
Ralph
Old Mar 4, 2007 | 10:33 AM
kortensi's Avatar
kortensi
How much Fusor did ya'll need to
1. bond the firewall to the birdcage
2. bond the front clip to the firewall?
KO
To How much Bonding Adhesive do I need
Old Mar 9, 2007 | 04:23 PM
kortensi's Avatar
kortensi
just wondering?
Old Mar 9, 2007 | 04:33 PM
rponfick's Avatar
rponfick
Not sure about birdcage, because I didn't mess with that. I think I bought 4 tubes and used about 3 1/2. But that included all the bonding to the firewall, including across in front of the windshield area, and new inner fender wells. Some clips you can get do not have the connecting section in front of the windshield. It would be better to have too much than too little, and I think you could return any unopened tubes.
Ralph.
Old Mar 10, 2007 | 06:04 PM
phrogs's Avatar
phrogs
Veteran: Marine Corps
I would say that enough is when you push on the pannels to set them that some squezes out of the seam, then you can smooth it with your finger. never to much if you ask me!
