Paint/Body Corvette Materials, Techniques, and How To
Under hood repaint
Old Mar 24, 2007 | 09:35 PM
Frankenvette 63's Avatar
Frankenvette 63
Default Under hood repaint
The under side of my hood (67 BB) had lots of old, bad paint, most of which was bubbled, dry and flaking off. I removed the hood and started sanding, but soon got into the fiberglass. So, I decided to use a razor, and it worked out pretty well. There are however some spots that the paint is stuck solid, especially on the edges (arrows). Long story short, the areas I can't remove, I want to feather with glaze and repaint. There are a few areas that have some hairs that I'll need to deal with. I don't have the equipment to paint professionally. This is a driver!
Any suggestions would be greatly appreciated!
Old Mar 24, 2007 | 10:59 PM
roger55's Avatar
roger55
Don't worry about the areas you can't get to, it's a driver. Sand by hand to get the rest off if it bothers you.
Looks to me like you are ready to wipe it down with a good wax & grease remover (make sure it's totally dry) and spray with 2 coats of SEM or Krylon.
I like the Krylon semi-flat and Walmart carries it.
Roger
