Paint/Body Corvette Materials, Techniques, and How To
Priming for Paint
Old Mar 25, 2007 | 07:55 PM
stinger12's Avatar
stinger12
Default Priming for Paint
Is priming a Vette for paint really that hard?
Old Mar 25, 2007 | 08:21 PM
sly vette's Avatar
sly vette
Not really, but the prep work before will either make or break the deal!!!
Old Mar 25, 2007 | 08:30 PM
SIXFOOTER's Avatar
SIXFOOTER
Yep, sand, sand, sand....then prime and sand some more
Old Mar 25, 2007 | 09:37 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
no its not hard but if the primer fails you are screwed....it just has to be done correctly, use the same paint "system" as the final paint and get the "paint guide book" from the paint store and follow it ,and you should be fine
Old Mar 25, 2007 | 09:38 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
It's not the painting, it's the prep. the sanding, body filler, the sanding, the sanding, did I mention the sanding?
Of course if you don't have to take off all the paint it's a lot easier.
Old Mar 25, 2007 | 10:27 PM
sly vette's Avatar
sly vette
https://www.corvetteforum.com/techti...=111&TopicID=3
Follow this paper!!!
Old Mar 25, 2007 | 10:29 PM
bobs77vet's Avatar
bobs77vet
and before you do anyting use a degreaser wax remover on all painted surfaces
Old Mar 25, 2007 | 10:32 PM
dennisb's Avatar
dennisb
any brand specific recommendation?
Old Mar 25, 2007 | 10:44 PM
sly vette's Avatar
sly vette
PPG DX 330 or 440
READ THE PAPER,ALL THE ANSWERS ARE THERE!!!!
Old Mar 25, 2007 | 11:01 PM
dannyman's Avatar
dannyman
Short answer, YES!!
Are you priming in preparation to paint the car yourself?
If you are, keep in mind that the prep work sets up the final product.
Any mistakes at this point will be magnified with final paint coatings.
If doing this yourself, it is a monumental task with questionable results.
I do not mean to question your talents, I will simply state; there are so many factors that determine the outcome of the quality of the paint, it is high risk to do yourself.
This is one job best left for a proper shop. From a health and safety point of view for yourself, to the end product of the car finish.
If your intention was to prep the car for the bodyshop, they won't warrant the paint job unless they do it all including prep.
Long answer, same as short, YES!!
Old Mar 25, 2007 | 11:28 PM
sly vette's Avatar
sly vette
I feel that a person with patience, the proper tools, and the paper by Lars that I posted a link to earlier, can do a very good home job. But you have to be willing to settle for nothing but perfection in your prep work!!!!!
Old Mar 26, 2007 | 09:50 PM
roger55's Avatar
roger55
Spraying primer is relatively easy and easy for a beginner to do.
Sanding primer (or "blocking") a car is an art and takes practice and hard for a beginner to do. If you are wanting an outstanding paint job on your car, get some guidance from someone with experience with this.
Roger
Old Mar 26, 2007 | 10:03 PM
roger55's Avatar
roger55
Maybe, but it could cause other issues like product incompatibilities.
Especially with lacquer. Delamination problems can occur over lacquer even when a sealer is used.
Also, total film thickness can be an issue, leading to paint cracking down the road.
It's almost always better to strip the car and use a high build primer to block the panels flat again. It doesn't take that long.
One thick coat of polyester primer and block with 100 grit (dry) on a long sanding board. Then another coat and block with 180 (dry) with the long board and you should have darn flat panels.
Roger
Old Mar 26, 2007 | 10:25 PM
roger55's Avatar
roger55
Originally Posted by dannyman
Short answer, YES!!
What you say makes perfect sense for some people but not for others.
It depends highly upon the person.
It can be learned if one is dedicated enough. Do-it-yourselfers are doing great jobs all the time and everyone has to start somewhere.
I have seen first time do-it-yourself paint jobs that were darn good.
You are right about safety. It is very important but isn't hard to learn about with a little research.
I do believe someone doing their first paint job has a lot better chance of success if they get some guidance from an acquaintance with experience. But that is not imperative. Again, it depends on the person.
Roger
Old Mar 26, 2007 | 10:54 PM
roger55's Avatar
roger55
Originally Posted by sly vette
Definitely some good info in that write-up.
Some things are not accurate. This is the only place I've seen SMC referred to anything else but "Sheet Molded Compound".
Also, SMC started on some panels in the early 70's, not all of a sudden in '82.
To Priming for Paint
