Corvette Bodyworkers....Step Inside a Moment
Anyone every attempt body owrk on their vette with good results. What products did you use? I would like to body work it. If I can;t get good results in the final finish, I'll let a shop paint it.
Thanks if you could lend some tips...
http://forums.corvetteforum.com/show...post1557671476
http://forums.corvetteforum.com/forumdisplay.php?f=138
Good luck
1 Clean the panel front and back with a initial prep cleaner
2 Sand an area down to the SMC that extends approximately 2 inches from the crack on the front and back side
3 Bevel the top side of the panel from the crack to about 1 inch back; start at the crack and sand the panel down to a point and bevel it back into the panel like a "V"
4 Scuff the both sides of the panel with 80 grit paper and dust off (DO NOT use a liquid prep on SMC under any circumstances!)
5 Apply the line specific patch (either DuraMix or AutoMix) using the compound as a glue
6 Once that has cured (check label for time; it is quick) fill the trough that you created on the top side if the panel making sure to keep the tip in the compound while pumping to avoid bubbles
7 Once cured you can sand and begin bodywork
On a superficial repair you will simply skip work on the back of the panel and perform all of your work on the top side just as described above.
NOTE: If using DuraMix you can not apply body fillers directly, you must use more of the repair compound to fill. If you use the AutoMix you can apply your fillers directly. If you have any direct questions about this process DuraMix sells a very good video on who to do this or you can post them here. This is the best and really only way to repair these panels for the life of the vehicle; they will not pop loose or separate even in a crash, truly amazing stuff! Hope this helps and these products are available through any paint and body store and even some local parts houses.
I respectively have to dis agree. The DuraMix/ Auto Mix is not "the only way" to make SMC repairs. I use the "old school" way to repair the stress and/or structural damage.
Using the same methods to prep the panels as you do, I use 1 1/2 oz. fiberglass mat with Fiberglass Evercoat SMC Resin to make the repairs. If it's just a stress crack, I use Evercoat's SMC Panel Adhesive to fill the v'd out area on the front side. You can use regular bondo (although I prefer Rage) to finish out the repair. With this method, there is no need for buying an expensive gun. This has worked well for me the past 20 or so years.
I do use the DuraMix to install new panels on the C4's however.
My .02
Dan
If you notice I wrote "life long" in that statement. What we have experienced with resin repairs (that we have had to work on or around) is not that the resin won't adhere to the SMC but that the resins become very hard once cured. A perfect example I have is a hood on a customers c4. It was repaired with mat/resin sometime ago before the current owner bought the vehicle. After a while the repair which is very hard and strong began to tear loose and crack the SMC around it. Essentially what he had was a very rigid, actually, too rigid of a repair and over time with the hood attempting to flex and the repair refusing to, the repair came loose. Now if the resin and mat you are using (which I have no direct experience with) better matches the structural properties of the SMC panels (which the Evercoat website does not address) it may not have this type of a problem and would avoid buying the guns. We just feel that the $60 for the applicator gun is well spent insurance that one of our $7000 jobs does not come back with a failed repair. So absolutely, the methods I listed may not be the only ways to repair SMC, but they are the only methods that we feel are truly for the life of the panel in that they precisely match the structural properties of the SMC. Have you repaired a quarter panel with your method? Was the repair able to flex with the panel or was the repair very stiff? I am curious and would like to look into this product but I am a little reluctant to try it out on a customer vehicle in the event that we would have a problem with it. Maybe a test panel off a car.......
Deakins
If your only experience with resin repairs is the one that you spoke of, then you don't know what kind of resin was really used in that repair. I agree, if the repair is made with regular ( as opposed to SMC resin) polyester fiberglass resin, the repair is doomed to fail. Most of the time, regular resin won't even feather out during the repair, it keeps peeling back. It's not that it's "too rigid", it just doesn't ad hear to the SMC, eventually it lets loose. The repair that you spoke of, in all likely-hood, didn't cause the SMC hood to crack. The cracks you saw around that repair were the ones someone was trying to repair.
When the C4's first came out, ( before Fiberglass Evercoat made SMC products) there was no way to repair those panels. I did some experimenting with epoxy fiberglass resin and mat to repair those first hits and they worked fine. The only drawback was the epoxy resin takes a lot longer to cure, and you have to maintain 65* - 70* for the first 24 hours or do the repair over.
To answer your question, Yes, I've repaired every SMC panel on a C4 at one time or another. I've never had a repair come loose or show up while using this method. I repaired one once, and a month later , the customer totaled the car. The panel broke about 6" on both sides of my repair, but my repair didn't crack. This was enough proof for me that my repairs we plenty durable enough.
Try it, you'll like it!
Dan
