How long does it really take to paint a vette
How long does it really take to paint a corvette without all the rigomoroe (having to to keep the car for 6 months etc)?
I should have been more specific, not a trailer queen job. A standard OEM paint job without the car taking a back seat to the collision work
(which is the bread and butter of a body shop)
I did mine in a week, and that's priming, sanding, sanding, wet sanding, more wet sanding, cleaning, cleaning, cleaning, washing, more washing, blowing the dust out..spraying for coats, block sanding with 400, blah...blah....blah...blah.....one week, of solid work.
If you strip it,seal it, primer it, wet sand it, color coat it and clear coat it.....perhaps a month or so. It depends on how much time you have on a daily basis. Mine had 4 color coats, one clear coat and 4 coats of primer. I used Citrustrip. it is fibreglass friendly. The more coats of paint you have, the more likely the paint is to crack.
I just got mine back Friday, the shop had it 2 1/2 months and that was working around the insurance jobs. They probably worked on it for 3 weeks out of the time. I had minimal body work and it was already media blasted when I took it in.
Well if you tape around the door handles....The replies will be all over the map as it depends on vehicle condition, quality and thoroughness of prep, painting of door jambs, replacement of weatherstripping, removal of door panels, follow-on buffing, etc. The time can also be dictated by any "surprises" found when the old paint is stripped. Some of those can be ugly.
But I can share with you my experience from 2005. The car had faded lacquer paint and minor spider cracking. As well two short sections of the bonding strips in the front valence had worked loose (see first pic). All hardware was removed as you can see from the pic including door SS trims and glass. Door panels were removed and the inner surfaces of the door painted. All new weatherstripping was glued/riveted on. The original SB hood was painted as well as a replacement hood in green/black. There is more but that will give you an idea.
Real time expended was 130 hours which is about three weeks. Turnaround time was just shy of three months. Hope this helps.
I would say a few weeks if you can convince them to do it that way, but most shops at least a month if not more. Some like to do cars in sets; body work, prime, paint several cars all at one time. You should probably see what your local options are.
You can paint a car in a day but the prep can take three to four weeks. I would say three to four months without your car is an average turn around time. If you wanted a paint and body shop to drop everything and do your car for three or four weeks straight and wanted to pay them the 30k to 40k+ they make for the month im sure they would. Most paint and body shops try to do multiple projects at once in order to pay the bills and still get the work out on time.
Obviously with what I said above and experienced I agree with Jake. It is much more expensive to undo a bad paintjob than to get a bad paintjob. Just a thought for those who plan to keep their Corvettes long-term. If you are planning to sell in the near future then a quick strip and a couple of coats of re-sale red may be in order.
Location: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
