I am in the process of replacing the front lower valance on my 69 and wanted to use their product as it is available locally.
I spoke with the tech department and they suggested using 105 epoxy resin, with 205(fast hardener) or 206(slow hardener), and then adding their 407 or 410 filler to do the final fairing.
Does this sound okay?
Anyone have hands on experience with these products?
Any help is welcome...
phillip
It will certainly work, but I have no experience with the specific product. You need something with a little body, so it dont sag and run off.
For your final fairing you want to use the microfibers if you need some strength with good sanding(403) and microballoons if your just filling and need easy sanding (Dont know the number offhand, think its 410).
i have used west system on both my cars a 61 that i bought a body in pieces and a 72 coupe that had an extensive crash,i chop lite cloth to mix in with the resin that gives body and strenth i have used the micro fillers also i have put on noses ,quarter panels ,bonded broken sections together and made panels with it dont know if it works on latter cars but it works on c1s and c3s
