Epoxy advice
epoxy over the primer mixed as a sealer as it would make the yellow
color cover easier. Today I sprayed two coats of the epoxy mixed
as a sealer which calls for 1/2 part reducer.
Problem is after the two coats the surface feels a bit rough with some
nibs and some orange peel.
What should I do next? Was thinking of wet sanding with 600 and applying one more coat. Instead should I use a scuff pad (400 to 600
paper equivalent) to remove the nibs and other trash before applying
one more coat. Or something different?
Excess moisture can cause a finish that looks like dirt also. Do you have a main moisture filter at the compressor and another disposable filter at the gun? If you are using an oil less style compressor, outdoors in the summer, moisture will be your enemy.
The orange peel could be too much air pressure, too wide a fan, or the speed you are going on each pass.
Back to the gun, are the internal passages of the gun clean? You may not be getting smooth air and fluid flow due to debris inside the head or siphon tube. When working with many of the modern paints, especially epoxy, the gun needs to be thoroughly cleaned after use (especially a primer gun) by spraying lots of thinner through it, otherwise it won't spray good.
I know I made several suggestions, so between Jim and mine, you need to figure out what makes sense.
thru it, but have not taken it apart in some time. I use it just for primer
and epoxy so it is overdue for a good cleaning.
I sprayed another coat today after water sanding and did not have
the orange peel problem. I think the problem was caused by the warmer temperature yesturday.
I would like to water sand this last coat with 600 before applying the
color. Any problem with wet sanding the epoxy and applying the color
without applying another coat of epoxy?
