Paint/Body Corvette Materials, Techniques, and How To
Foam eggcrate vs wool
Old Jan 8, 2008 | 09:17 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Default Foam eggcrate vs wool
Question is simple,,does the foam cut faster than the wool ?? considering your using the same compound.
Old Jan 12, 2008 | 01:24 AM
AZ Z51's Avatar
AZ Z51
St. Jude Donor '05
When you cut a buff you want to use a wool pad,and then use a foam pad with a finsh glaze to remove the swirls.
Old Jan 12, 2008 | 08:36 AM
roger55's Avatar
roger55
That's how I do it.
I use the Schlegal wool pads on a power buffer and use the foam pad on a D/A for the finish glaze.
I've tried cutting with foam pads on a power buffer, but I've not had any luck doing that. Went back to the wool pads.
Old Jan 12, 2008 | 03:33 PM
Michel B's Avatar
Michel B
Thanks,, !!!!!
To Foam eggcrate vs wool
