Paint/Body Corvette Materials, Techniques, and How To
bonding nose
Old Jan 31, 2008 | 08:22 AM
babylonvette's Avatar
babylonvette
Default bonding nose
i finished fitting the complete nose[used] i am installing, fitted and ajusted a few times, ready for final bonding ,can i do i side at a time or do i have to do all at once that means undoing rad support again , also i am using chopped glass with epoxy reson as had used this system on other parts of car and it works great [west system ] it is a 72 coupeals i am using a strap to tighten nose to bonding section at firewall ,not drilling and screwing as some people suggest
Old Jan 31, 2008 | 09:44 PM
wombvette's Avatar
wombvette
With epoxy and this time of year, you should have plenty of time to do the whole thing at once.
Old Feb 1, 2008 | 12:23 AM
babylonvette
i don;t think you understood what i asked or i worded it wrong, i want to lift up each section and put epoxy in without completely removing nose again, it seems like i can pry apart and get almost all sections fairly easy ,the only hard to get section is the drivers side front firewall where it is a little tight to get in because of the air vacumn tank otherwise i can get to all spots wher adhesive needs to be
Old Feb 1, 2008 | 01:40 AM
wombvette's Avatar
wombvette
OK, I guess you could do that.
Old Feb 1, 2008 | 05:33 AM
65convt's Avatar
65convt
Are you sure the straps are going to hold the nose in place tight enough.
I've hung many noses years ago, drill & rivet in place. Drill out rivets later and fill with glass. Just my $.02.
Good Luck with your project!
Old Feb 1, 2008 | 07:48 AM
babylonvette
yes i did a few on solid axle cars you wrap the strap arround the chassis and over the nose at the bondind spots then pull strap tight i suppurted it in critical spots with 2x4;s to even out the pressure its a teqinec that someone showed me years ago that way, you don;t have to fix the small holes and they wouldn;t come back to bight you in years to come , you can also shim out the panels if they are in too far like this
Old Feb 2, 2008 | 09:16 PM
babylonvette
nose was removed to do at once it was shimmed and supported in spots i will check on finnished product on monday and let you all know how it came out i would post pictures but i don,t know how
To bonding nose
