Paint/Body Corvette Materials, Techniques, and How To
Using metal etching primer
Old Apr 25, 2008 | 10:35 AM
Olustee bus's Avatar
Olustee bus
Veteran: National Guard
Default Using metal etching primer
I read in the c2 section that using a metal etching primer then a polyester primer is asking for trouble. That is what I did. After doing that, it was painted with basecoat.clearcoat.
I di not like the color so I scuffed the clear coat. I now have a different painter who is going to put a coat of epoxy primer over the clearcoat.
If I am going to have problems, when will it show up. I put stripped it, primered it and had it painted about a year ago. I have not repainted it yet.
Should I strip it again?
Old Apr 25, 2008 | 11:31 AM
Scott Marzahl's Avatar
Scott Marzahl
I would certainly call the customer rep for the poly primer you used and tell them what you shot it over and see what they have to say. Also call the primer customer service line and ask if it is ok for over bare glass. I think Jim covered it pretty well in the C2 section.
Old Apr 25, 2008 | 11:18 PM
roger55's Avatar
roger55
I hope there is someone out there that has experience with poly primer over etching primer that can say what will happen.
However, as you have been told, poly should not be used over etching.
Based on that, if it were me, I would definitely strip it again.
Old Apr 26, 2008 | 10:07 AM
porchdog's Avatar
porchdog
i do not use etch on anything , not even metal much less on glass.. it causes too many failures. epoxy has proven to have better adheasion . i would not invest in new paint over something like this.
To Using metal etching primer
