Epoxy tube brand name
Not that long ago, someone posted a brand name of an epoxy product that comes in a dual tube syringe used for small body work for early C3 (1973) vettes. Does anyone have the brand? Can't find the post for the life of me.
Thanks.
Thanks.
I think that was me. It's called "Power Poxy For Pro's". Available at Menards and probably other home centers/hardware stores. I've used it effectively to repair SMC. I've used Adtech SMC repair epoxy (that Eckler's sells) side by side with it and as far as I can tell it works just as well. I used it on my own Vette too. I was curious and cut up some SMC pieces and tried some other types of Power Poxy epoxies. Other's didn't work as well ...some didn't even adhere to the SMC. I suggested to Ecklers to test it and sell it in a 'small crack repair kit'. Actually a tube goes a long way. Good luck
Mark G
Mark G
Mark G
Mark G
3M, Lord Fusor, and SEM all offer excellent quality adhesives designed for automotive use. The main difference in these brands is the cost of the applicator gun, SEM being the least expensive. You did not specify what materials you are gluing together, such as smc to steel or smc to smc, the are specific adhesives for each type of material you want to glue as well as short and long curing times depending on how long it will take you to align the parts. Your paint store or the mfr. web sites can help you out.
Make sure you use an adhesive designed for the materials you want to glue together as well as an adhesive that is designed for automotive use and is proven to withstand the automotive environment. Even the General messed up on the adhesive used to glue the smc roof panels on '98-02 "F" bodies resulting in the adhesive leaching through the smc, so you can't be too carefull with your selection, and I would avoid the home store stuff.
Fusor is great. Just finished a 72 and put on flares and a complete front end. Bullet proof once it hardens. Make sure the surfaces are roughed up pretty good and the bite is excellent. You can find a used gun every now and then on ebay. Mine will be for sale soon.
Norm
Norm
