Paint/Body Corvette Materials, Techniques, and How To
Painted Pinstripe Removal
Old Aug 2, 2008 | 12:06 AM
droq172's Avatar
droq172
Default Painted Pinstripe Removal
I just finished removing the painted pinstripes on my 2001 Speedway White coupe. They had been on since the summer of 2002 (prior to me owning the car). After reading about it here on CF, I used Easy Off - Heavy Duty, oven cleaner. I am glad I didn't pay a bodyshop to take them off. It only cost me the $6.00 for the can of Easy Off and about 1.5 hours of my time and a little elbow grease. I also recomend wearing gloves my finger tips are pretty tore up.
Old Aug 2, 2008 | 01:38 AM
Dave Tracy's Avatar
Dave Tracy
Old Aug 4, 2008 | 03:51 AM
TioSterling's Avatar
TioSterling
wow glad to see they came off with that. I always wet sand them off with 2000 grit sand paper but then it leaves a line that you have to wet sand more to straighten out then buff.. helpful hint, thanks
Old Aug 4, 2008 | 01:03 PM
droq172's Avatar
droq172
I don't know how this would work on darker colors of Corvettes. I am lucky tat my car is white and there is very little paint fade. I don't know that I would have done this on a Black or Blue car.
Old Aug 5, 2008 | 07:07 PM
ChrisKo's Avatar
ChrisKo
When you say Paint fade, is it faded from the oven cleaner or you the difference of the paint that was exposed to sun vs. the paint that was under the pinstripe?
Old Aug 6, 2008 | 10:08 AM
Pocket Aces's Avatar
Pocket Aces
Yeah I am confused. Painted pinstripe would mean sanding through the stripe to remove it, which would mean sanding through the clear at some stage. I think this is a decal pinstripe.
Old Aug 6, 2008 | 12:04 PM
Black94LT1's Avatar
Black94LT1
Cruise-In 10-11-12 Veteran
St. Jude Donor '09-'10-'11-'12-'14
I'm guessing these are the painted on pinstripes done by hand after the clear is applied.
Old Aug 6, 2008 | 12:56 PM
droq172's Avatar
droq172
These were painted pinstripes done after/on top of the clear coat. The paint fade was sun caused not chemical caused. Like I said I can see a very faint line but I think after waxing the car it will go away.
Old Aug 20, 2008 | 08:23 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
What you're seeing is the "tatoo" of the pinstripe paint. Years ago, I had an oval track car, and had one of the sponsor's business name lettered on the car. Two seasons later, he bailed out on me. I used the "oven cleaner" trick to remove the lettering paint, which was probably similar to the pinstripe paint. But there was still the faint image where the chemicals of the lettering paint had etched into the base color.
To Painted Pinstripe Removal
