Paint/Body Corvette Materials, Techniques, and How To
Basecoat/clear question?
Old Aug 22, 2008 | 09:27 PM
kmillar's Avatar
kmillar
Default Basecoat/clear question?
I'm painting a black '90 corvette and I'm a bit concerned with dirt in the basecoat, then clearing over top of the base. Is it a recommended practice to wet sand the base, with say 1000 grit, then just clear over this if you are concerned with dirt/debris in the paint?
P.S. I already clean the area throughly, tack everything down.... I'm just concerned with having dust under my clearcoat and not being able to do anything about it. Any advice would be appreciated.
Old Aug 23, 2008 | 02:03 AM
Scott Marzahl's Avatar
Scott Marzahl
I'd nib out any dirt/dust with 1500 and then clear it.
Old Sep 11, 2008 | 12:06 PM
Noel@AutoBuffs's Avatar
Noel@AutoBuffs
Former Vendor
St. Jude Donor '09
I would not recommend this unless your going to re-shoot the base coat then clear!
Old Sep 11, 2008 | 12:32 PM
porchdog's Avatar
porchdog
i get one covered good then take care of any trash or spots ??? usually by hitting with 600 then put on a final coat of base. much like clear. i put down 3 coats then block with 600 then 2 final coats. makes for less peel and trash to deal with.
just a suggestion thrown out there
Old Sep 11, 2008 | 12:34 PM
JimiHendrix's Avatar
JimiHendrix
Is that because you are not suppose to sand the base coat in a B/C system? I.E. all of the sanding is done on the epoxy primer coat? right? thanks in advance
To Basecoat/clear question?
