Paint/Body Corvette Materials, Techniques, and How To
Door jamb prep
Old Nov 4, 2008 | 12:02 AM
Blain's Avatar
Blain
Default Door jamb prep
Can't find any info on the prep of door jambs. Short of chemical strip or media blast how do you old body guys do it?
Blain
Old Nov 4, 2008 | 04:05 AM
Polish Painter's Avatar
Polish Painter
If the paint is in good shape, just clean well with alcohol , wax and grease remover. Scuff with red scotchbrite and scuffing paste or ajax.
Reclean , seal,base,clear.
Old Nov 4, 2008 | 08:42 AM
79vetter's Avatar
79vetter
I think he's asking how to strip the jams. I would be curious to know as well. If you use a stripper it tends to run down on a vertical surface.
Anyone else?
Old Nov 4, 2008 | 08:20 PM
P Knopp's Avatar
P Knopp
I just did mine using chemical strip on the parts I could reach, wasn't so bad take your time. Mine had 5 coats of paint so I needed to get back to glass. In the recess where the hinges mount I used a little hand held sand blaster, 5 minites work two hours of cleaning sand out of everywhere.
Old Nov 5, 2008 | 11:01 AM
Blain's Avatar
Blain
I was considering sand on the inside door shell. What size of sand did you use? I've been using 30# mesh but it seems too aggressive.
Blain
Old Nov 5, 2008 | 11:58 AM
mayordaly's Avatar
mayordaly
For doing door jambs that are hard to reach, I just used a small drill and steel wire brush at first then went to a brass wire after I got to the primer. It worked great for me. Also used a dremel tool to get back
deeper into the back of the hinge area.
Old Nov 5, 2008 | 09:09 PM
Scott Marzahl's Avatar
Scott Marzahl
I used #70 sand on my door shells, its very fine and does a nice job.
Old Nov 5, 2008 | 11:49 PM
Blain's Avatar
Blain
Hey Scott, did you do the 'glass side of the shells or just the steel side?
Blain
Old Nov 6, 2008 | 02:20 PM
P Knopp's Avatar
P Knopp
I used #30 but only blasted the inner metal parts. Also this was with doors and hinges off .
Old Nov 7, 2008 | 10:18 AM
Scott Marzahl
Only the steel portion of the shells. If you want to do the glass, look into buying some #6 acrylic beads.
Old Nov 7, 2008 | 11:45 AM
Blain's Avatar
Blain
I think I'll try the acrylic beads if I can find them in the area
Blain
Old Nov 28, 2008 | 08:24 PM
34RedRage's Avatar
34RedRage
i find the best way is to remove the doors from the car and prep and paint off the car,
To Door jamb prep
