Paint/Body Corvette Materials, Techniques, and How To
Removing paint
Old Feb 15, 2009 | 07:37 PM
JIMS1970VETTE's Avatar
JIMS1970VETTE
Default Removing paint
Hello, I am going to strip the paint off my 1971 coupe with a chemical stripper at a friends shop, any thoughts?
Old Feb 15, 2009 | 07:42 PM
SIXFOOTER's Avatar
SIXFOOTER
good plan. What stripper are you going to use? Be sure and neutralize it once the paint is removed, use plenty of ventilation and gloves
Old Feb 15, 2009 | 07:49 PM
C3 4ME's Avatar
C3 4ME
I used Capt'n Lee's to strip mine. It took it down to the last coat of primer and then I sanded it from there. I don't know if another coat would have taken the primer off or not, but figured it was better for the stripper not to touch the bare fiberglass. Mine sat for a month after being stripped before any primer or paint was applied. I washed it thourougly with water to neutralize the stripper and then went over the whole car with laquer thinner.
Old Feb 15, 2009 | 07:51 PM
HawkIVette's Avatar
HawkIVette
If your in to doing things yourself, that is a great way and good advice above.
I was not in to that, so I went for the media blast process.
It cost me a trip by trailer to and back from the media blaster and $450 for his service, but is sure looked great.
Old Feb 15, 2009 | 07:57 PM
JIMS1970VETTE
Thanks for the replies and I hope to have it stripped in a week and then like you guys were saying, to let it offgas and wipe it down with thinner before primering. I will keep you updated and with some pics.
Old Feb 15, 2009 | 08:08 PM
sly vette's Avatar
sly vette
Just soften the paint up a bit with a heat gun and then use a dull putty knife to scrape it off. Real easy but be careful not to concentrate too much heat and blister the paint.
Old Feb 15, 2009 | 09:30 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Razor blades are easier, cheaper, faster, safer, better, probably more.
Paint stripper sucks.
It's like scraping a sticker off a winshield. Usually it's really easy.
( once in a while you will find paint that is bonded too well for razor blades)
I did my whole car with razor blades, Except the primer, I sanded that off.
Went from this
To this
to this
Old Feb 15, 2009 | 10:42 PM
swtato's Avatar
swtato
St. Jude Donor '05
Razorblades were pretty easy and a D/A sander occasionally. It is amazing how the pait just flies off once you get going.
From this:
to this:
To the final product! worth all the prep work!:
Old Feb 15, 2009 | 11:17 PM
milo30's Avatar
milo30
Captain lee's worked good for me. The biggest thing is to let it do it's job before you try to remove it.....and wear gloves. I found that If I took a putty knife and put a scratch in the paint, it would use that area to find its way under the paint and then come off really easily. I'd do it outside because of the fumes.
Old Feb 15, 2009 | 11:40 PM
71coupe454's Avatar
71coupe454
Check this guys video of stripping with razor blades.
http://www.corvette-restoration.com/...ng%20paint.AVI
Old Feb 15, 2009 | 11:45 PM
BigBlockTank's Avatar
BigBlockTank
I learned how to paint in the USAF, in 1975. I also learned to do sheetmetal and fiberglass (well, composites) also. I was told repeatedly not to use a chemical stripper on fiberglass. The chemical stripper would leave deposits that would ruin a paint job. Don't ask how I learned this on a $3,000 paint job, but I fixed it.
So, for me, no chemical stripper, even though I know I'm anold school fart. I'm sure there is some chemical strippers that work just fine on 'glass, just not my 'glass.
I prefer PolyPlus plastic beads, with a very low air pressure. I can take the "paint" off of a Coke can without distorting the aluminum can. Blasting 'glass after that is a ole fat cake job. my $.02
BBTank
Old Feb 16, 2009 | 11:32 AM
Sully1882's Avatar
Sully1882
On my 72 coupe, it had two paint job on top on the original steel cities grey... I used razorblades and am almost done with the DA sander work. Went very quick once I got the hang of it! Either razor it and deal with the dust and scrappings or you can use a chem stripper and deal with the fumes and mush. Your choice and your car... many people have used both techniques and ended up with beautiful end products. Good luck with the process.
Sully
Old Feb 16, 2009 | 06:53 PM
JackDidley's Avatar
JackDidley
I think it depends on the paint you are dealing with. I have taken them down to bare glass 4 times. C3 factory paint is a piece of cake. Use any method mentioned here. I did my C3 in a day and a half with stripper. Had it painted with Imron. 12 years and 200000 miles later it was time to do it again. I stripped, sanded and scraped for days before I was done. C4, factory paint sands off easily. The one I'm doing now has 5 coats of base, 5 clear and 2 primer, not so fun.
Old Feb 16, 2009 | 07:26 PM
porchdog's Avatar
porchdog
never use thinner to wipe down glass. it drys too fast and leaves the residue in the glass.best is to use a water base cleaner or dawn soap.
Old Feb 17, 2009 | 12:37 AM
JIMS1970VETTE
Hi, thanks for the replies, also I would like to replace the hood with a LT-1 hood, there is the press molded and the other type, any thoughts.
Old Feb 22, 2009 | 11:14 AM
JIMS1970VETTE
Well I hope to start stripping the car tomorrow, pics will follow. And my friend said he can get a nice LT-1 hood for me also.
To Removing paint
