Paint/Body Corvette Materials, Techniques, and How To
Lars Paper and project
Old Mar 25, 2009 | 10:40 AM
SargeZ06's Avatar
SargeZ06
Default Lars Paper and project
Is Lars paint paper still an up to date source? I noticed the rev. I have is 1-12-03.
I have a major project ahead of me and I have never tackled body work. Anything mechanical is no problem.
I have removed the widebody fenders off of my 71 and I'm going to use L88 flares. The original fenders and quarters are still intact and weren't removed when the widebody panels were molded in. Now I have to remove a lot of resin and clean things up.
I also have to remove the paint from the rest of the car.
I'll add some pics in a few.
Steve
Old Mar 25, 2009 | 11:15 AM
crazywelder's Avatar
crazywelder
Do you have a link to it?
Old Mar 25, 2009 | 11:17 AM
SargeZ06's Avatar
SargeZ06
It's the one on the corvettefaq.com
http://www.corvettefaq.com/c3/PaintTechPaper2.doc
Old Mar 25, 2009 | 11:44 AM
crazywelder
Not much has changed, it's a good well written procedure. Every car is different, so from a detailed level you may need to change some of the steps or products to fit your project and material availability.
Old Mar 25, 2009 | 12:52 PM
SargeZ06's Avatar
SargeZ06
In the 6th shot you can see that some of the glass was pulled loose when I removed the panel. What should I hit that with? Resin? Filler?
Old Mar 25, 2009 | 03:26 PM
crazywelder
Resin and mat, but you'll need to remove the rest of the bondo to really see the extent of the repair. I would sand/grind the remaining bondo off of the panels. It will be a pain and a mess, but sanding will do less damage to the fiberglass.
Old Mar 25, 2009 | 07:22 PM
SargeZ06's Avatar
SargeZ06
Should I just take it down with 80 grit on my orbital?
Old Mar 25, 2009 | 08:03 PM
crazywelder
Yes. If you feel confident you can start with 36 grit. If your sander has a lockable shaft for grinding that will help speed things up. Otherwise it will be a long process with an orbital.
To Lars Paper and project
