How do you setup a spray gun as far as getting the flow right. Ive adjusted the fan pattern and the volume nozzles to death and i cant seem to get that good flow. If found i have to go real slow to get the flow right our ill get alot of orange peel in the clear. I was only able to get it right once and after i was done the part didnt really need any wet sanding it looked that good. Its a clear coat gun only
fan wide open , 2 1/2 to 3 turns out on fluid , keep 4 to 6 inches off the panel. i run mine at 22 - 25 lbs. with spi uv clear.
orange peel = fluid adjustment
runs = air pressure
runs = air pressure
