Paint/Body Corvette Materials, Techniques, and How To
paint prep question
Old May 14, 2009 | 04:55 PM
KEG64's Avatar
KEG64
Default paint prep question
I am doing a color change on an 86. The interior and doors have been gutted. I would like to paint the interior floorboards, rear hatch area and inside the doors with a SS. What is the minimum prep work I should need to do before painting these areas?
Old May 15, 2009 | 11:13 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
it depends on what is already there? why paint the floorboards?
they will be covered by carpet,
spend your time installing heat/sound deadner instead.
Old May 15, 2009 | 12:01 PM
J. Scott's Avatar
J. Scott
I just replaced the carpet in my '80. As I knew the carpet had gotten wet from time to time I was prepared to find rust. Surprisingly I found nothing but a little surface rust. We first washed the area with some detergent to remove any grease. After that I removed all the loose rust with a wire brush wheel on a drill. The final step was to cover those spots with Eastwood's Rust Encapsulator which is essentially a spray pint that kills rust. Check their anti-rust products out here: http://www.eastwoodco.com/jump.jsp?i...ORY&itemID=372
Hope this helps.
To paint prep question
