Paint/Body Corvette Materials, Techniques, and How To
fixing paint issues ?
Old May 19, 2009 | 11:04 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Default fixing paint issues ?
ok I fianlly got the SPI epoxy sprayed, and then 1 coat of base,
I had to stop due to several issues, mostly I had 2 spots where the epoxy had ran and I did not see it until after the base,
can I just sand these areas down and reshoot base over them ?
sanding recomendations ? 320 then 600 and reshoot the base ?
also I have several small diviots about 1/16" dia. will the clear fill and cover these ?
my biggest mistake was using gray epoxy, and spraying silver paint !
hard to tell the epoxy from the paint !
thanks for your suggestions ! 69VETT
Old May 29, 2009 | 11:08 PM
nitromainia's Avatar
nitromainia
[QUOTE=69Vett;1570136142]ok I fianlly got the SPI epoxy sprayed, and then 1 coat of base,
thanks for your suggestions ! 69VETT[/QUOTE Block 'em... try not to blow through the primer- and re-base No problem
