body repairs
they were built with really cheap resins in the early years. and never use cheap 2nd line materials on fiberglass . if you cant afford quality materials you cant afford a vette . spi epoxy is all i use to surface . hope this helps.
I sure wouldn't try it on a painted car! That said, I just trace coat all repairs in satin black Laquer .....Then leave in the sun for several days or more .....Another interesting theory is to do the above and occasionally hose down the repairs with cold water then allow to re-heat and "sunbake" 10 to 15 "heat cycles" The idea is expansion and contraction also helps in offgassing and shinkage.... Then final block- and SPI prime- also good (required!) to sunbake the primer a few days- I Also use Vette Bond ....by Evercoat for final shape on all repairs Great stuff
