I recently purchased my first Vette; a 1970 convertible with 30,000 documented miles. Everything works great on the car excpet for the two inside tail lights.
My question is: Are all 4 tail lights (2 on each side) suppose light up when the brakes are applied? Right now, the two inside tail lights do not work whatsoever. They don't work when the brakes are applied, blinkers, whe the head lights are turned on, nor do the backup lights activate when in reverse. The two OUTSIDE tail lights work when brakes are applied, blinkers, and when the headlights are turned on. The two inside tail lights, however, never light up at all.
When are the two inside tail lights suppose to work? ie; when brakes are applied? Blinkers? When in reverse to activate the backup lights?
Thank you in advance for any answers or suggertions you might have.
