cleaning contaminated area
Is the epoxy reacting to these "stains" to the point that it is not curing and staying wet or remaining glossy when the other areas are dulling out.?
"DUB"
I really have a problem with using any type of soap on fiberglass/SMC. IT will absorb into the panel and possible cause for other problems due to not being able to get it out. I use solvents. Such as acetone, lacquer thinner, and even 3M adhesive remover. Each has their uses and depends on the circumstances in which one I use. Wipe on with one lint free wiper..and remove with another CLEAN lint free wiper...and not just smear it around until it dries by using one wiper. All you are doing is speading the oil around and not removing it. Then use ANOTHER CLEAN wiper and do it again. DO not re-use the wipers...they will re-apply what you have removed. And maybe again and again and so on.
You can apply heat with a heat gun...but be careful not to get it way to hot. But yet hot enough to see if the oil will "sweat out" and be removed with the solvent when it cools. If you start seeing dark gray spots...that is the oil being drawn to the heat source. If you have no dark gray spots...then the panel is not saturated enough to cause this issue. Next paragraph explains further...
You did not respond to my earlier post and check the inside of the fender. This is important. Until you identify the source or cause of the problem...you will still have a problem...maybe not at the time of spraying ...but in the future when the oil causes your paint to bubble.
Were the emblem holes filled in and this is the area of the fisheyes? Could be contaminated filler and may need to be removed and replaced with fresh filler.
When you are prepping for epoxy primer...is the panel showing signs of discoloration? Like a darker gray color? Or is it staying all the same color....light gray.
If this presists...and seeing how I have no good photo's to look at...I would grind down the problem area and apply a decent coat of Fiberglass/Evercoat Vette Panel adhesive and then sand it so the primer can be applied.
If you insist on using a wax and grease remover....which I do not on bare fiberglass/SMC....because if the body is rough...and the outer layer of SMC has been sanded on...even with 320 grit...and the structure of teh SMC is now "open" due to this sanding....I consider this ROUGH....and the wax and grease remover will leave behind deposits that you can not wipe off due to it being absorbed into the body. IF you choose to do so...you MUST let it dry WELL so you are not trapping any foreign material in the structure of the finerglass. We are dealing wil a contaminant on the microscopic level here.... or at least I am assuming so due to needing very good photo's to better aid me in helping you.
"DUB"
From my last post til your last post...what did you try to do to correct this? You did not mention any of your repair procedures IN DETAIL....other than applying more epoxy and 2K primer.
From your photo's. I would grind and apply epoxy resin and matt. Making sure that you grind enough to get to good SMC that is not contaminated. BUT without imput from you on the options of solvents and other processes you can try...it is hard to say anything unless you keep us informed. I am unable to advise you further unless I know what you have done....if anything. I have numerous ways of repairing this problem...racing around in my head...but they are useless...if one..if not all... of the earlier mentioned ideas has not been tried.
"DUB"
If I grind the area out and lay new matt and resin, how can I lay it on the backside of the panel and build outward to the surface?
