Paint/Body Corvette Materials, Techniques, and How To
swirl marks????
Old Jul 18, 2010 | 09:00 PM
darkstallion_69's Avatar
darkstallion_69
Default swirl marks????
I have some really bad swirl marks on my passenger side from the hood passed the rear of the door. It looks like it might have been from rubbing compound as the paint is perfect everywhere except there. I tried 3m swirl mark remover by hand and it really didnt help. Would using a high speed buffer be the next step. Its driving me insane. luckily in the daytime u cant see it since its white but at night its pretty visible. Any help would be appreciated.
Old Jul 19, 2010 | 12:12 PM
71white's Avatar
71white
You can go to the detail section and they will give you the "perfect" way to fix this. all I did was to use the swirl mark remover and a cheap orbital wax machine from Pep Boys and it worked perfect!! go slow and do a 3 foot section at a time until it is good and then move on the the next section. Perfection takes time.
Old Jul 21, 2010 | 05:02 PM
Scott Marzahl's Avatar
Scott Marzahl
If you do not have a buffer with a selection of wool and foam pads and the associated compounds required, take it to a reputable detail shop and have them use either polish followed by swirl remover or swirl remover depending on how bad the surface is cut.
Old Jul 26, 2010 | 07:11 PM
4440stevesvette's Avatar
4440stevesvette
Go to a well known detail shop and have them do it right. This is not something a novice should play around with!
To swirl marks????
