Paint/Body Corvette Materials, Techniques, and How To
SEM primer
Old Jun 16, 2011 | 12:20 AM
mrg's Avatar
mrg
Default SEM primer
Is using SEM rattle can high build primer ok for use in C2 bodywork to fill in slight high/low areas of the repair? ..
Old Jun 16, 2011 | 11:07 AM
Scott Marzahl's Avatar
Scott Marzahl
That sounds like a bad idea, rattle cans are mostly solvent and may or may not be compatible with what you put on next.
Old Jun 16, 2011 | 02:20 PM
SuperL98's Avatar
SuperL98
If you absolutely have to use a spray can primer, Eastwood has a 2K epoxy (in a can).
It has the hardener in an internal chamber that you pierce before using.
Say's 4 day pot life, but I had the best luck using it all up right away.
Beige color and sands pretty easy also.
Bit pricey.
http://www.eastwood.com/spray-max-ep...r-aerosol.html
I've used it on my rear bumper .... haven't sprayed over it yet
The SprayMax page
http://www.spraymax.com/index.php?id=351&L=1
they have a high build also
http://www.spraymax.com/index.php?id=352&L=1
Old Jun 17, 2011 | 12:46 PM
mrg's Avatar
mrg
Ok, thanks guys. .. I had thought the SEM primer was 'ok' compared to other spray can stuff. Thanks for providing the links, SuperL98.
To SEM primer
