Paint/Body Corvette Materials, Techniques, and How To
C5 rocker remove/replace
Old Jul 23, 2011 | 10:54 PM
KOZ's Avatar
KOZ
Default C5 rocker remove/replace
Can anyone offer insight into the R&R of the rockers? What else has to come off? Can I replace them without a ton of issues?
Thanks,
-KOZ
Old Jul 25, 2011 | 12:08 PM
KOZ's Avatar
KOZ
Anyone?
Old Jul 25, 2011 | 09:37 PM
CF6873's Avatar
CF6873
If they are damaged I would repair them with SMC repair products.
I'm quite sure that they are bonded on and would be a lot of work to replace.
Craig
Old Sep 12, 2011 | 12:34 AM
cebars's Avatar
cebars
Check out Section 8 - 209 of the Service Manual.
Door Opening Frame Replacement:
Removal Procedure:
1. Disable SIR system
2. Disconnect negative battery cable
3. Visually inspect for damage to the frame rails oor wheelhouse mounting areas. Repair.....
4. Remove all panels and components to gain access to door side frame. The door side frame can be removed if the quarter panel is loosened from it. This may include removeal of the following components:
- door
- quarter panel
- quarter panel inner spash shield
5. Remove latch striker closeout cover and striker
6. Remove the trim screws that attache the side door frame panel to the rail. These screws must be re-installed to secrure the service panel in place until the adhesive cures.
NB Ensure that the fule inslet is sealed before proceeding with the repair procedure.
7. Use caution along the underside of the vehicle when applying heat not to de-bond the floor panels from the frame rail.
8. Apply heat and pry to break bond along area (1)
Pic shows (1) as underside of frame rail where door opening frame (aka rocker panel plus door frame).
A ton of work.
Old Sep 12, 2011 | 11:10 AM
KOZ's Avatar
KOZ
Will then...I think that settles that. I'm not gonna do it.
Thanks for the info!
To C5 rocker remove/replace
