Paint/Body Corvette Materials, Techniques, and How To
quarter panel reshoot
Old Aug 11, 2019 | 01:42 PM
standardbyke22's Avatar
standardbyke22
Default quarter panel reshoot
Hello,
I painted my 68 last sunday, it went good however i got a bad run and water drop spot on the drivers quarter panel, the run was in the basecoat, i want to hit those bad spots with some base and re clear the whole panel, i think thats the best way to go from what ive read, however what grit should i wetsand the panel to for the base and clear to stick good and not show a ton of scratches?
Old Aug 11, 2019 | 10:18 PM
keith ragan's Avatar
keith ragan
I start with 600 and finish with 800. Depending on what color the car is you may have to fade the paint out over most of the panel to get a good match.
Old Aug 12, 2019 | 08:41 AM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
did you clear the panel after the base coat run?
If so
scuff the entire panel with a white scuff pad
sand your run down with a block and 600 / 800
re base it
re clear it
Old Aug 12, 2019 | 10:50 PM
standardbyke22
the color is black, the run was in the base. and i did clear the panel.
would wet sanding the whole panel with 600, leveling the run, hit with 800 wet, spot base the bad spots and clear whole panel be fine?
Old Aug 13, 2019 | 08:44 AM
csherman's Avatar
csherman
solid black should be fine
fade / blend / step your color out from the run
To quarter panel reshoot
