Paint/Body Corvette Materials, Techniques, and How To
Firewall/Undercarriage paint
Old Nov 17, 2019 | 06:05 PM
DWinTX's Avatar
DWinTX
Default Firewall/Undercarriage paint
Wondering what you guys use to paint the firewall and undercarriage with. When I see the restored cars, it looks like a semi-gloss black. Any particular type or brand work best?
Old Nov 17, 2019 | 09:05 PM
Norm07's Avatar
Norm07
I used Rustoleum Proffesional over an epoxy primer. Reasonably priced and sprayed out very nice. Got the info off one of the Hot RodForums.
I mixed the Rustoleum 1.5 Quarts of Flat Black to 1 Quart Semi Gloss to get the desired sheen. This was after a fair bit of experiment. I used Acetone as a reducer and a hardner that was compatible with the enamel (hard to find and EXPENSIVE!). I sprayed with a Harbour Freight HVLP sprayer with a 1.8mm tip.
Mix. 8 Paint - 4 Acetone -1 Hardner
Old Nov 17, 2019 | 10:33 PM
CamarosRus's Avatar
CamarosRus
SPI Epoxy Primer ordered DIRECTLY from https://www.southernpolyurethanes.com/
and delivered TO YOUR DOOR (No Jobber, No Store, No Middleman)
Used on Below Underfloor
Then I used PPG Delfleet Essential Urethane mixed to semi Gloss formula on Firewall
SEE the results.......!!!!!!!!!!
Body was Sandblasted Prior to SPI Epoxy
Old Nov 18, 2019 | 09:22 AM
DWinTX's Avatar
DWinTX
OK, thanks for the suggestions guys. Those both look great!
To Firewall/Undercarriage paint
